Wouldn’t the drag caused by the flaps just decrease the acceleration, so, although they can lift off at a lower speed, wouldn’t it be faster to just use no flaps and rotate at the higher speed that is required?
    $\begingroup$ Note that usually flaps can be extended to different settings. The one used for takeoff create less drag than the one used for landing. Moreover, while on ground, you may take into account tyres and wheels restrictions and other acceleration penalties due to undercarriage. $\endgroup$
    – Manu H
    Commented Nov 9, 2019 at 10:03
    $\begingroup$ This question needs some help. The question is different from the title. The question appears to be asking whether it would take less time (not distance) to leave the ground with flaps up. The title is asking something completely different. Please fix! $\endgroup$ Commented Nov 9, 2019 at 13:08
  • $\begingroup$ Great answers but... see above. $\endgroup$ Commented Nov 9, 2019 at 13:11
    $\begingroup$ The take-off technique for the Me-262 was to accelerate with flaps up and to lower them only at the take-off speed. That opened up the use of runways which were nominally too short for a standard take-off with flaps set to 20°. Your reasoning is correct, but when something fails, you are in deep trouble. $\endgroup$ Commented Nov 10, 2019 at 7:18
Increasing the flaps does increase the drag, but not by that much initially. For the first stages of flaps you gain more by reducing required takeoff speed. If you would increase the flaps more and more, eventually the drag would become too much and you would lose takeoff distance again.
Flap setting has an affect on the wing’s lift coefficient and on the aerodynamic drag. Increasing flap angle increases the lift coefficient, and therefore reduces stalling speed and the required takeoff speed (the same lift will be created at smaller air speed due to greater lift coefficient). This reduces the takeoff distance. In the same time increased flap angle increases drag, reduces acceleration, and increases the takeoff distance.
The net effect is that takeoff distance will decrease with increase of flap angle initially, but above a certain flap angle the takeoff distance will increase again. An optimum takeoff setting can be determined for each type of aircraft and any deviation from this setting will give an increase in the takeoff distance.
The flap setting also affects the climb gradient. Increasing the flap angle increases the drag, and so reduces the climb gradient for a given aircraft mass. If there are obstacles to be considered in the takeoff flight path, the flap setting that gives the shortest takeoff distance may not give the required climb gradient for obstacle clearance.
(skybrary.aero)
Note that the climb gradient is also affected:
affect of flaps on climb gradient
More flaps allows taking off from shorter runways, but reduces obstacle clearance capabilities.
    $\begingroup$ I would suggest that sometimes the climb gradient is better with some amount of flaps deployed. $\endgroup$ Commented Nov 9, 2019 at 13:14
    $\begingroup$ I might be wrong about that-- at least for no wind case. I think is surely true sometimes w/ strong headwind. $\endgroup$ Commented Nov 9, 2019 at 13:36
    $\begingroup$ Downvote for asserting that climb gradient is worse with flaps extended. It's almost always better (of course only up to a certain flap extension angle). Climb rate is usually best with flaps fully retracted, if the comparison is made at a steady-state condition rather than during acceleration. $\endgroup$ Commented Nov 10, 2019 at 8:25
  • $\begingroup$ @pericynthion Did you read the page I quoted? "Increasing the flap angle increases the drag, and so reduces the climb gradient for a given aircraft mass." $\endgroup$
    – Bianfable
    Commented Nov 10, 2019 at 11:12
    $\begingroup$ Instead of "better climb gradient" and "worse climb gradient", an improvement here would be using more objective and common phrases like "increased climb angle" and "decreased climb angle." Better and worse are subjective terms and depend on what one is trying to accomplish. Sometimes a decreased climb angle results in a faster climb and that's better. $\endgroup$
    – Suncat2000
    Commented Jul 29, 2020 at 19:37
Because without flaps extended there is less safety margin for stalling in the landing.
Picture above from this answer shows the lift coefficient as function of the angle of attack. With flaps extended, a certain amount of lift is reached at a lower AoA than without flaps.
It is a safety feature during landing, when speed needs to be reduced as much as possible. Not so much during take-off, and TO flaps setting is often not fully deployed. But deploying them does reduce TO distance since the same lift can be reached at a lower speed.
    $\begingroup$ The graphic is deceptive, as typically when you lower flaps on an airfoil (no slats) while $c_{L_{max}}$ increases, the AOA at which you hit $c_{L_{max}}$ decreases. Your plot shows the AOA for $c_{L_{max}}$ increasing. Nice article showing this result. n91cz.com/AOA/… $\endgroup$
    – MikeY
    Commented Nov 19, 2019 at 0:42
  • $\begingroup$ @MikeY Yes indeed. $\endgroup$
    – Koyovis
    Commented Nov 19, 2019 at 4:50
Wouldn't it be better to use no flaps, and rotate at the higher speed that is required?
Well, now we are talking about a short field take off. If you ever watched Lindbergh's takeoff the day of the famous journey across the Atlantic non-stop flight, barely clearing a power line on climb out, or even actually done one off a muddy or snowy runway, you know the answer to this question.
Many take-offs are done with flaps up because an aircraft will produce more lift per given amount of thrust (drag) " clean ". Key to this is reaching the speed where the wing can be set to its optimal Lift to Drag ratio AOA and also be going fast enough to produce adequate lift.
Cambering up a wing makes it a better lifter, giving the ability to get the plane off the ground at a lower speed, but at the expense of more drag (read thrust and drag interchangably).
Notice the same effect can be achieved by increasing the coefficient of lift of an unflapped wing by raising the AOA past optimal L/D ratio, but the risk is, especially with wings that stall at a lower AOA, the power on stall!
So if the runway is covered with take-off roll drag producing items such as mud or snow, or simply is not long enough to reach flaps up takeoff speed, we use some flaps and slats to get airborne and climbing as soon as possible.
Once airborne, it is generally best to retract flaps and climb out Vy, unless that obstacle needs to be cleared, then we use the less efficient Vx.
Increasing camber (and AOA) does increase amount of lift at a given speed, but will require a proportionally greater amount of thrust. A bigger or turbocharged engine helps here, along with careful monitoring of airspeed.
    $\begingroup$ Note: flaps make high AOA, low speed flight slightly safer by stalling the wing near the root first, similar to dropping leading edge slats near the wing tips, or having "washout" built into the wing. $\endgroup$ Commented Nov 9, 2019 at 15:12
    $\begingroup$ Once you get off the ground, you can accelerate much faster than when the wheels are down there in the dirt, grass, or whatever. Even on a paved runway, the tires create quite a bit of rolling resistance, as anyone who's moved a light plane by hand should realize. $\endgroup$
    – jamesqf
    Commented Nov 9, 2019 at 17:58
    $\begingroup$ That's true. Watching the Lindbergh film, they towed the plane out with 2 cars, so I wonder if ... $\endgroup$ Commented Nov 9, 2019 at 18:08
    $\begingroup$ "Most take-offs are done with flaps up." Jetliner takeoffs are done with the flaps lowered to a takeoff setting, typically around 10 degrees. $\endgroup$
    – Terry
    Commented Nov 16, 2019 at 19:39
