59
Looking at some videos and photos of F/A-18 Hornets and Super Hornets taking off from carriers and from airfields, I recognised that the left rudder is pointing right, and the right rudder pointing left.
Here's a picture:
Enter image description here
  • Why is that? Are there any aerodynamic advantages?
  • Is it also used as an airbrake to slow the plane down at landings?
  • At which point of the flights are the rudders in this position and why? (Takeoff, landing, cruising, or both?)
  • Does the pilot steer them or is the work done by a computer?
4 Answers 4
76
Living Wing
The Super Hornet has a living wing, that is to say, the shape of the wing is constantly in motion throughout every regime of flight. Trailing edge flaps, leading edge flaps, stabs, rudders, and ailerons all move in concert to give the pilot the greatest control during particular phases of flight.
This is evident by the use of the flaps switch. The three flap positions are, Auto (Up), Half, and Full. Up auto means that the flight control system (FCS) will dynamically change the wing based on what it thinks the pilot is trying to do. However, when the flaps switch is placed in the half and full positions the FCS switches to landing mode, and all flight control inputs will be interpreted as such. Even though the flaps switch has been placed to half/full, the pilot has only changed the FCS logic, he has not actually commanded the flaps to a fixed position. There are no fixed gains (flaps positions) like there are in typical commercial aircraft. Instead, the computer adjusts the flaps position to mimic a flaps half/full position, while also giving the pilot the most stable platform it can for landing. The logic has its limits though and if the pilot exceeds 14 AoA in a landing mode (flaps half or full), the FCS may accidently depart the jet. This is obviously bad 200 ft above the ground. This switch commands the FCS to make flight control decisions and is the toggle between the tactical, and landing modes of flight.
Rudder Toe-In
The particular effect you are referencing is called rudder toe-in. At slower speeds, particularly during high angles of attack, the stabilators may not provide sufficient nose authority to crisply rotate the nose. The massive wing area of the Rhino tends to block the airflow over the stabs. To remedy this problem the Rhino's rudders will automatically bias to the inside and create a downward force, which pitches the nose upwards. While the rudder is toed-in, the pilot can still use the rudders to yaw the aircraft. The FCS selectively moves the rudder position to generate the yawing motion, even while retaining the fared-in position.
Take-off and Landing
During takeoff the rudder will remain in the toe-in position for a fixed 10 seconds after it detects weight off the wheels. This prevents the aircraft from accidentally faring the rudders (and losing nose authority) during one of the most critical phases of flight (AoA probe failures will actually cause the rudders to automatically fare, and this problem is removed by a fixed timing.) During the landing portion of flight, the rudders will also be fared in to give the aircraft more nose authority, and this is handled automatically by the FCS once the pilot commands the aircraft into landing mode by placing the flaps switch out of up auto.
Other Functions
While the Rhino does have small speed brakes that extend during full speedbrake deployment, the primary method of increasing drag to rapidly slow the aircraft is through the use of the control surfaces. The FCS will increase the drag by lowering the flaps, toeing-in the rudders, lowing the ailerons, and deflecting the stabs, all while still giving the pilot a stable platform to fly the aircraft--it's an impressive aircraft.
During high alpha maneuvering, the Rhino will again deflect the rudders to the toed-in position while the flaps switch is in up auto. With the FCS logic in auto, the computers will attempt to retain control of the aircraft during max performance maneuvers, and will automatically schedule the flaps and rudders to compensate for high AoA and slow speed flight. Because the nose is cocked up and the airflow is disrupted over the stabs, the rudders will again create that pitching force that will assist the pilot in maintaining nose authority through any regime of flight.
Emergencies
As stated before, there are times when the rudders may suddenly fare themselves which can have devastating effects during the final portion to land. Rudder failures are serious problems and should be treated as such. Higher landing speeds and extra caution will be used, and the pilot should understand that wave offs may be impossible due to lack of nose authority in close to the ramp.
  • $\begingroup$ Thanks for your answer! Are there any known incidents caused by rudder failures? $\endgroup$
    – jklingler
    Aug 23, 2015 at 8:48
  • $\begingroup$ @jklingler That sounds like a new and separate question. You should probably post it as such. $\endgroup$
    – J...
    Aug 24, 2015 at 12:30
    $\begingroup$ What does "faring" mean? $\endgroup$
    – cpast
    Aug 24, 2015 at 21:27
    $\begingroup$ @Rhino driver, I was surprised to see you use the nickname "Rhino" to refer to the F-18. I thought this nickname was for the F-4 phantom, some research (coastcomp.com/av/fltline2/nickname.htm ) shows this. Where did you get this from? $\endgroup$ Jan 16, 2018 at 19:39
    $\begingroup$ @CharlesBretana From Wikipedia article on Super Hornet: "To aid safe flight operations and prevent confusion in radio calls, the Super Hornet is informally referred to as the "Rhino" to distinguish it from earlier Hornets. (The "Rhino" nickname was previously applied to the McDonnell Douglas F-4 Phantom II, which was retired from the fleet in 1987.) " $\endgroup$
    – Zebrafish
    Jul 1, 2019 at 15:08
30
The rudders are deflected inwards during takeoff of the F/A-18E to help in raising the nose of the aircraft as it leaves the ship. As the vertical fins are canted outwards, deflecting both the rudders inwards generates a downforce, which, due to its location aft of the center of gravity, creates a pitch-up moment.
This position of rudders during takeoff is common to all F-18s, including the Canadian CF-18s, which are not used in carrier operations.
CF 18 takeoff Source: mybirdie.ca
Almost all aircraft with a canted tail (F22, F35, etc.) can (and do) use their rudders for pitching in concert with elevators. The rudders are used during landing too. The principle is not much different and the FBW computer handles all these control surface operations usually.
F-18 landing Source: reddit.com
The rudders are also used as airbrakes. The F18 had an airbrake, which was removed in F/A-18E/F, and the control surfaces are used as airbrakes.
F18 tailhook "FA-18 Trap" by Original uploader was E2a2j at en.wikipedia - Transferred from en.wikipedia; transferred to Commons by User:Mo7amedsalim using CommonsHelper.. Licensed under Public Domain via Commons.
The rudders are in this position during takeoff/landing and once the aircraft is cruising, they become inline with the vertical tail to reduce drag. However, they can be used for decelerating the aircraft in flight, if required. Again, it is the computer which does the work.
F22 speedbraking? Source: www.f-16.net/forum/
26
The real reason: Ground effect was not considered during development.
Ground effect reduces the lift curve slope of lifting surfaces, and the low tail position of the F-18 makes this effect very noticeable during take-off. During development, this effect was not considered and, consequently, the F-18 could not rotate at the calculated speed when it went into flight testing. This increased the take-off distance and demanded an increase in pitch-up authority at low speed. As Jan Roskam explains in his book "Roskam's Airplane War Stories" (War story 108):
When the first F-18 fighter […] was flight tested at Patuxent River, it became evident that the airplane would not rotate at the predicted speed. This made the field performance of the airplane unacceptable. The problem was traced to an error in the calculation of aerodynamic forces in ground effect. This is particularly severe in case of a low placed horizontal stabilizer. As a result there was insufficient down-load capability to effect early rotation during the takeoff ground roll.
The problem was fixed by toe-in of the rudders. A squat-switch on the main gear biasses the rudders to deflect inward while on the ground. This creates enough positive pressure over the aft fuselage to effect early rotation.
This fix, although impressive, came at a price. All flight control software had to be revalidated. Also, the squat-switches represented additional system complexity.
There is another reason: With rudders fixed, the F-18 is longitudinally unstable at angle of attacks between 7° and 11° (see left plot below). By scheduling the extent of toe-in over angle of attack (see middle plot), the airplane can be stabilized (see right plot below). The graph below is copied from this MIT presentation and should explain the trick nicely:
effect of rudder toe-in scheduling on longitudinal static stability
Note that the rudder toe-in is already used in the original F-18A, not just the Super Hornets and their "living wings".
  • $\begingroup$ Is the squat switch you refer to not already present in the system? It sounds like they could have tapped into the same Weight On Wheels signal used for other control systems in the aircraft. Does that use a different set of sensors? $\endgroup$ Feb 27, 2017 at 4:36
  • $\begingroup$ @ChrisIversen: I guess you need to ask Jan Roskam. I would suspect that the toe-in is coupled with the flaps - there are enough pictures with F-18s already in the air and toe-in still active. Would make more sense, too. But Jan wants to make a point: Engineers should think of all effects in combination, and revalidation is really expensive. $\endgroup$ Feb 27, 2017 at 5:12
    $\begingroup$ Doesn't ground effect increase the lift coefficient? Clarification for that part in the answer would be appreciated. $\endgroup$
    – user14897
    Sep 9, 2019 at 23:29
    $\begingroup$ @ymb1: That source is rather rudimentary. As I understand it, ground effect affects the zero-lift angle also and the impact on lift coefficient changes over AoA. At high angle of attack it reduces lift, that is what happened to the F-18 tail. Lift pointing downwards in that case, of course. $\endgroup$ Sep 10, 2019 at 19:51
    $\begingroup$ @ymb1: Right, the upward acceleration of air hits a wall because the full circulation pattern cannot unfold as it can in free stream. The AoA is a matter of geometric definitions, so the lift curve slope in the linked graph should not be straight. Please see NASA TN D-4228 – it shows a loss of lift near the ground at high angles of attack. $\endgroup$ Sep 11, 2019 at 4:55
It's the rudders acting like a ruddervator to assist in pitching up. This is possible because they lean outwards a bit.
