When the Airbus A320’s flight control system is operating in mechanical law (the simplest and lowest-tech of the A320’s flight control laws, where deflections of the pilots’ joysticks are transmitted directly to the control surfaces via ye olde hydraulickes, with absolutely no envelope protections at all; mechanical law is the A320’s only completely non-fly-by-wire flight control law, and is generally only used in the event of an utter and total failure of the aircraft’s flight control computers), the aircraft’s ailerons and spoilerons are inoperative, and lateral control is accomplished solely by means of the rudder.
However, the rudder is a horrible lateral control surface; its intended purpose is for directional control, controlling yaw, not roll. Although an aircraft’s rudder can, in a pinch, be used to roll the aircraft in whichever direction the rudder is deflected, it does this indirectly, by inducing sideslip. The rudder, being quite close to the aircraft’s centerline, produces only a small direct rolling moment - which, to make matters worse, for aircraft with the rudder mounted above the aircraft’s center of mass (e.g., essentially all commercial airliners, the A320 included), is in the wrong direction. Thus, if one wants to turn right, and applies right rudder to that effect, the aircraft will initially roll slightly to the left, then stop, then, as the nose yaws to the right and the sideslip angle grows, finally roll suddenly and violently to the right. Once you’re actually in a turn, the situation is improved not at all, as now you have to religiously avoid applying any further rudder in the direction of the turn, lest you start skidding (turning with an excess of yaw, resulting in the aircraft’s nose pointing to the inside of the turn), which is an excellent, time-tested way of entering an unrecoverable spin and making your insurance company give your family lots of money.
If one had to choose just one set of control surfaces to use when turning, one would think that the optimal choice would be the lateral controls (ailerons and spoilerons), not the directional controls (rudder); that way, the required turning technique would be essentially unchanged from during normal flight, as modern aircraft do not use the rudder at all under normal circumstances (advances in aileron design1 having freed newer designs from the severe adverse yaw that bedeviled the Wrights and was the rudder’s original raison d’etre).2 Indeed, the A320’s stateside counterpart, the Boeing 737, does exactly this; when operating in manual reversion (the closest 737 equivalent to the A320’s mechanical law, given that the A320 inexplicably has no manual-reversion capability despite being small enough that it should have been a breeze to include), the 737’s rudder is (nominally) inoperative,3 and the aircraft is turned using only the ailerons and spoilerons.
Given the immense superiority of the ailerons and spoilerons over the rudder for lateral control, why did the A320’s designers go with the latter?
1: Consisting of various ways of artificially increasing the drag experienced by the falling wing in order to balance out the increase in induced drag on the rising wing resulting from its downturned aileron. The major way of doing this is simply by adding spoilerons to the system, which has the double benefit of eliminating adverse yaw (or even turning it into proverse yaw - that is, yaw in the direction of the turn, rather than out of it) and considerably increasing roll authority (especially at low speeds - and, hence, high angles of attack - where the maximum downwards aileron deflection is severely restricted to avoid stalling the rising wing, which would produce a rolling moment in the wrong direction, somewhat hampering one’s efforts to turn the plane in the direction intended); other methods include deflecting the upturned aileron on the falling wing much further from its faired position than the downturned aileron on the rising wing (thus balancing out the increase in induced drag on the downturned aileron with an equal or greater increase in pressure drag - and, at the transonic cruising speeds of modern jetliners, potentially wave drag as well - on the upturned aileron) and building the ailerons such that, when deflected upwards, part of the hinge end of the aileron protrudes below the wing (where it produces extra drag on the now-falling wing to balance out the extra drag on the now-rising wing).
2: In modern aircraft, the rudder is only used when it is necessary, for some reason, to generate a large sideslip angle, with these cases falling into three general categories:
  • The rudder’s design case (the scenario that places the greatest demand on the rudder, and, thus, determines the minimum control authority - and, thus, indirectly, the size - required of the rudder) is an engine failure at low speed, with the absolute worst case being a sudden, total failure of the furthest-outboard engine during takeoff, immediately after V1. At these low speeds, the rudder has to be large - especially on wing-engined aircraft - to counter the large yawing moment from a failed engine, which is why the rudder has enough control authority to overpower the lateral controls at low speed, which is why all aircraft have a crossover airspeed.
  • The most common use of the rudder, in contrast, is during crosswind landings, where the aircraft, in order to keep its nose pointed into the relative wind during the descent and flare, has to approach the runway with a large crab angle (i.e., with the aircraft’s longitudinal axis forming a large angle with that of the runway, rather than the two being parallel, or, ideally, coinciding), and then, upon mainwheel touchdown, must immediately (within a second or two) yaw to the runway heading (which requires a very high yaw rate, especially with a high crosswind component and resultant very large crab angle, and, thus - as the tiller can’t be used for steering until the nosewheel touches down, and, at any rate, would be largely ineffective, except at destroying the nosewheel tyres, at the high speeds of a touching-down jetliner - a sudden, large rudder input) in order to avoid running off the side of the runway.
  • The third main rudder-use scenario is if the aircraft has to turn suddenly when moving at speed on the ground (for instance, to avoid colliding with a baggagecart/deer/other plane/very lost driver/inattentive groundcrewperson/tiger griffin/tumbleweed that’s somehow found its way onto the runway you’re using to take off and/or land). In this case, the aircraft cannot roll, because the ground is in the way, so the rudder (along with differential braking, and, at lower speeds, some tiller input) is used to turn the aircraft.
3: In actuality, a small amount of rudder deflection is available in manual-reversion flight if enough force is applied to the rudder pedals, due to the specifics of the design of the 737’s rudder control system.
    $\begingroup$ I skim-read the question, but see this answer, particularly the last bullet point. $\endgroup$
    – user14897
    Mar 15, 2019 at 3:29
    $\begingroup$ You might like to consider making your questions a little shorter and focus on the key points. A long, detailed question suggests - rightly or wrongly - that a long, detailed answer may be needed. That tends to turn off people who could answer, and it doesn't fit the StackExchange philosophy of specific, answerable questions. $\endgroup$
    – Pondlife
    Mar 15, 2019 at 3:41
    $\begingroup$ You normally never touch the rudder pedals in a jet once airborne unless an\ engine fails or you are landing. But if you've ever tried applying rudder-only in a swept wing jet, you quickly discover you can get pretty snappy roll rates with very small amounts of yaw. $\endgroup$
    Mar 15, 2019 at 4:46
    $\begingroup$ While long, it is a well written question, "which is an excellent, time-tested way of entering an unrecoverable spin and making your insurance company give your family lots of money." $\endgroup$
    – FreeMan
    Mar 15, 2019 at 12:15
    $\begingroup$ The joysticks don't have any cables, etc. attached to them. In mechanical back-up, where electrical systems are lost, there's just no way to have them control the ailerons. $\endgroup$
    – TomMcW
    Mar 15, 2019 at 21:35
11
OK, what you call "mechanical law" isn't a "law", it's mechanical signalling. So it needs steel cables from somewhere in the cockpit to whatever chosen flight controls.
The A320 already uses steel cables for the Rudder - that's how it's normally signalled. So there's no extra work involved in doing this. For pitch control, the Stab Trim Wheel is never used in normal flight, but has steel cables going to the Stab, so this is used in mechanical signalling mode.
The aircraft is perfectly flyable (if you broaden the definition of 'flyable' a little) in mechanical signalling mode, but lots of things have to fail to get you down to that level.
  • $\begingroup$ very interesting answer; may be you may be helpful for the following:I discovered lately that the mechanical backup of the B777 apparently doesn’t use the rudder but only the THS and 2 symmetrical spoilers(N°4 and N°11), however to loose totally the electrical power and to exhaust the batteries I am obliged to imagine the loss of an engine, so my worries how to fly the aircraft without the rudder in this case?Is it possible the THS and 2 spoilers to be sufficient with a modulated power of the remaining engine? If you have a solution please answer the question I have posted. Kind Regards $\endgroup$
    – user40476
    Jun 16, 2019 at 19:23
Yes indeed. But ultimately, in order to direct an aeroplane to the desired location, we need to control three degrees-of-freedom: fwd/aft, left/right, up/down.
  • fwd/aft control is achieved via the engines, or by trading in potential energy for kinetic energy during a glide.
  • left/right control is via rolling and/or yawing the aeroplane. Rolling is only preferred because it is much more comfortable for anyone, however when the chips are down in rare situations, comfort is not the first priority.
  • up/down via the elevators or horizontal tail.
Mechanical back-up in the A320 is for being able to control the aeroplane when all the flight control computers are down and out. And the rudder provides the necessary back-up control, more suitable for landing in a side wind than the ailerons do.
    $\begingroup$ "And the rudder provides the necessary back-up control, more suitable for landing in a side wind than the ailerons do."- I wonder if this is true. Would be interesting to play with a flight simulator and find out, w/ a realistic flight model of an airliner. Consider that--even in zero wind-- if you make a have to make a last-second roll correction with the rudder to stop yourself from touching down in a banked attitude and dragging a wingtip, this may involve so much yaw and slip that you may touch down with more sideload on the gear than you would in a no-rudder landing in a strong xwind. $\endgroup$ Feb 12, 2020 at 15:12
    $\begingroup$ I know for sure if I were landing, say, a Cessna 172 I would much rather have aileron and not rudder rather than vice versa. The roll authority is much better in the former case, and so what if touchdown is highly crabbed in a sidewind with no ability to do either a cross-countrolled-sideslip or a last-second "de-crab" maneuver? The landing gear can probably take it. On the other hand I've flown a small number sailplanes w/ small vert fins that are literally uncontrollable w/ pilot's feet off rudder pedals. In such cases it would be better to have only the rudder than only the ailerons. $\endgroup$ Feb 12, 2020 at 15:18
    $\begingroup$ But if the rudder on A320 is assumed locked near centered rather than free-floating and pilot is controlling roll with only ailerons or only spoilerons, I would bet the resulting flight characteristics would be far superior to the case where the ailerons are locked near center and the pilot is trying to accomplish roll control with only the rudder. I may be wrong. Ample dihedral and resulting unfavorable coupling between adverse yaw and roll is one reason the sailplane w/ small fins was uncontrollable w/ free-floating rudder, and airliners do have significant dihedral effect due to sweep. $\endgroup$ Feb 12, 2020 at 15:27
