I am coming to this with an amateur understanding of CL, Cp and their contribution to the overall lift of a wing, so bear with me :)
I have been wondering for some time about whether you could design a system of slats (perhaps multiple stages of them) that deploy in tandem with flaps as to prevent the nose down pitch moment experienced on a typical wing when flaps are deployed. The idea is to bring the leading edge of the wing forwards and down, to extend the overall chord length, and in turn bring the relative aoa back to what it was before, but with a much higher cl-max (and of course lots of drag)?
The main idea behind this is that it would be very useful for canard aircraft if deployed on both the main wing and the canard. In theory it could greatly reduce the minimum speed and distance for takeoff without changing the lift ratios or messing with the cl/cg relationship. It seems like an elegant solution and I am puzzled as to why no one has done it yet? Am I missing something?
I apologise if this doesn't make sense. As I say, I'm still getting to grips with the concepts.
