I understand that aircraft with canards are designed so that they pitch down when at a high angle of attack. The canard is designed to stall before the main wing, thus the canard produces no lift force, and pitches down around the CG, preventing the main wing from reaching its stall angle.
How are the canards designed to stall first, is it aspect ratio, sweep angle, cross section? The Long-EZ has a straight canard and a tapered, swept main wing yet some jet canards are as swept as the main wing.
I’m looking at applying this idea to a RC model aircraft to give it better performance. Just an amateur rc hobbyist.
  • $\begingroup$ You forgot “incidence” $\endgroup$
    – Jim
    Oct 19, 2022 at 1:50
How are the canards designed to stall first?
Canards are normally built with a very high aspect ratio: this gives a quite sharp stall and at a quite low AoA. But that's not the whole story. Canard design is a sensitive (and also quite interesting) tradeoff among contrasting characteristics.
Why is canard configuration so sensitive? Let's suppose that, for whatever reason, the nose of the aircraft goes up. In order for the aircraft to be stable, it must respond pushing the nose back down.
When the nose goes up, the AoA of both the canard and the wing increase and their lifts increase accordingly. A bigger lift generates a bigger downwash. Now, the downwash of the wing doesn't bother us that much since behind the wing there's basically nothing important in a canard configuration. But the downwash of the canard does matter to us because it impinges on the wing thus reducing the local AoA of the wing.
So, a nose up movement of the aircraft translates in an increment of the canard's lift plus an increment of the wing's lift although smaller. But bigger lift in front means nose up tendency. Therefore, if the nose of the aircraft goes up, a canard configuration pushes the nose even more up: the canard configuration is fundamentally unstable.
How can this instability be cured? There are basically 3 things which can be done and each one has pros and cons.
  1. The CG is shifted as far as possible from the wing's aerodynamic center (i.e. as forward as possible); this can be achieved for example sweeping the wing back: its weight and its aerodynamic center shift backward and this has the same effect as shifting the total CG forward toward the canard. But! a more forward CG also implies that a big part of the weight must be now lifted by the canard which therefore has to generate more lift and more downwash, exacerbating at the end the just explained instability.
  2. The canard is built in such a way as to generate always less lift than the wing, also taking into account that its downwash blows on the wing reducing the wing's AoA and lift. This can be achieved for example if: a) the canard has a smaller surface than the wing (1:4 for example for the Rutan VariEze); this normally also implies that the canard's span is smaller than the wing's one and its downwash now impinges on a smaller portion of the wing; b) the canard is built with a very high aspect ratio; this gives a well defined stall and at a lower AoA; c) an airfoil is chosen possessing a quite flat $C_L \text{vs } \alpha$ curve around the stall:
canard lift coefficient of Rutan VariEze
  • This plot from this NASA report shows the lift coefficient of the canard of the Rutan VariEze (circles) in respect to a standard NACA 0012 airfoil (squares): as visible, the stall region is well defined for the VariEze while for the NACA 0012 there's a region after the pick where the lift goes down and then up again; furthermore "canard stall occurred at about $\alpha$ = 13°, whereas wing stall occurred at about 21°".
  1. We take to the extreme the previous solution and we simply download completely the canard; it now generates lift only to control the aircraft and only in a relative small amount and its shape can be now more or less freely chosen; the instability problem due to the downwash is gone but now there's another problem: if the canard does not lift anymore, then the whole weight is supported by the wing alone i.e. the CG is now very close to the aerodynamic center of the wing; unless the wing is designed self-stable, this condition is not only unstable (again) but this instability is normally quite fast as well and the only way to counteract it is via an automatic stability system which is not really an option on small general aviation airplanes.
If you see canard aircraft with a relative big canard surface, think about the point 1.
If you see a Rutan's aircraft, think about the point 2.
And if you see an Eurofighter, think about point 3.
  • $\begingroup$ Are you sure you read the plot correctly? Could it be that the canard lift is referenced to the main wing area, making your comparison misleading? $\endgroup$ Oct 20, 2022 at 19:50
  • $\begingroup$ @PeterKämpf Yep, you're 100% right: they call $C'_{L_c}$ the lift coefficient in respect to the canard surface, I totally missed the single quote. I'll update immediately the answer. $\endgroup$
    – sophit
    Oct 20, 2022 at 20:14
  • $\begingroup$ @PeterKämpf: done, thanks for spotting it $\endgroup$
    – sophit
    Oct 20, 2022 at 20:28
  • $\begingroup$ I'm still unhappy with your answer because it is plain wrong. The canard lift coefficient is higher than that of the wing. This makes it stall first, so the plane pitches down. $\endgroup$ Oct 21, 2022 at 14:09
  • $\begingroup$ @PeterKämpf: done! I posted the cl Vs alpha of the canard, this time the right one 😅 $\endgroup$
    – sophit
    Oct 21, 2022 at 15:19
An airfoil stalls when its angle of attack (the angle at which the airfoil meets the incoming wind) exceeds its critical angle of attack. So, it's simply a matter of arranging it so the canard reaches its critical AoA before the main wing.
One simple way to do this is to rotate the canard back by a tiny bit. If the canard's angle of incidence (the angle at which the airfoil is tilted relative to the body of the aircraft) is higher than that of the main wing, then its AoA is going to be higher by the same amount.
Another (probably more common) way is to use a different design for the canard that has a lower critical AoA.
Of course, there are more esoteric options available, such as designing the body so that the the airflow at the canard has a slight upward motion, increasing the canard's effective AoA. But that would depend heavily on the exact shape of the body, and wouldn't be possible for most designs.
Fun fact: On conventional tailed airplanes, the center of gravity is in front of the center of lift of the wing, meaning the tail actually has to generate a slight downforce to keep the plane balanced. The designers of those planes use these same techniques to ensure the main wing (at least partially) stalls before the tail, for exactly the same reason.
  • $\begingroup$ The airflow at the canard has a always an upward component due to the presence of the canard itself (at least at subsonic speed). On aircrafts of conventional design, tail stalls definitely after the wing for understandable safety reasons: having a wing producing a not-controllable aerodynamic force is not funny $\endgroup$
    – sophit
    Oct 19, 2022 at 6:28
  • $\begingroup$ @sophit Ah, yes, I got the stall part backward. But do you have a reference for "he airflow at the canard has a always an upward component"? How can the airflow already have an upward component when the canard is the first thing it reaches? $\endgroup$ Oct 19, 2022 at 13:25
  • $\begingroup$ I simply mean the upwash :) $\endgroup$
    – sophit
    Oct 19, 2022 at 14:41
How are canards designed to stall before the main wing?
By making the airplane longitudinally stable. When canard and wing stall at comparable angles of attack, the canard will stall first when the whole airplane is longitudinally stable. Stability is achieved by flying the canard at a higher lift coefficient than the wing, which in turn is made possible by a larger angle of incidence (calculated from the zero-lift angle) of the canard.
The same is done on conventional airplanes by giving the wing a higher incidence than the tail. In both cases the rear surface has a smaller angle of attack and flies in the downwash of the forward surface, reducing the local angle of attack again. A downforce is not required. In case of a canard the downwash only affects the inner wing and the outer wing flies in the upwash of the canard wake, making a canard less robust against a roll departure near stall.
