I read an article about how the new B21 would have (in theory) a W shaped trailing edge, which was the initial shape intended for the B2 before the gust alleviation system was added to the requirements causing it to have the sawtooth trailing edge.
From what I see from the planform of the B2, there aren't any more unique angles on the sawtooth compared to the W shaped trailing edge even though it has more 'sides'.
I was wondering if this is true in that the W shaped trailing edge has better stealth characteristics than the sawtooth edge and if so, is it significant?
The article mentions Bill Sweetman's Inside the Stealth Bomber book as its source.
