Bending aluminum for a map box, and am curious as to the folded dimension of a sectional chart. My present resources use moving maps on EFIS and iPad, but I would like to carry standard paper charts.
$\begingroup$ Your best bed is to get an actual chart which runs for less than $10 $\endgroup$ – Steve Kuo Oct 30 '17 at 16:02
One seller's link on Amazon claimed 10" x 5", but when I measured an old one (only one I have handy), it was between 10.25" and 10.5" long by 5" wide. So I'd recommend using the latter value, knowing that the chart will probably be a hair under 10.5" long and so you have room for error (or a badly refolded chart).
$\begingroup$ A Van's map box kit has a 12" depth, my application only allows 11.5". The actual measurement provides positive verification, thanks. $\endgroup$ – drPete Oct 30 '17 at 23:24
