Were planned release dates skipped in 2020 for the VFR sectional charts for Juneau Alaska and Dutch Harbor Alaska?
On February 3 2021, the FAA's "Raster Charts" webpage listed a March 26 2020 date for the latest edition of the Juneau sectional, and a February 27 2019 date for the latest edition of the Dutch Harbor sectional. These dates seem unusually old. (And interestingly, at that time, the links to those editions didn't even work.)
There was a rather significant airspace change at PASI at Sitka Alaska (which is located on the Juneau chart), effective November 5 2020, which appears to coincide with what should have been a planned release date for this chart. The E2 Class-E-to-surface airspace at Sitka was changed from an "L" shape with arms to the northwest and southwest, to a nearly circular shape with a very large rectangular E4 Class-E-to-surface "extension" projecting toward the northwest. As of February 3 2021, the current VFR sectional products available online still showed the old airspace configuration, while the new airspace configuration could be seen by going to the LAANC map and typing "PASI" in the search window and enabling the E2 and E4 layers. (Images of each attached below-- screenshots taken February 3, 2021.)
It seems odd that such a major change in airspace configuration would not have been covered by new edition of the VFR sectional chart. Was a release of the Juneau chart planned for November 5, 2020, and then skipped for some reason?
Bonus: if so, for what reason?
The rather low "edition numbers" shown on the current edition of the FAA's "Raster Charts" webpage for many of the Alaska charts does suggest that they generally been released only about half as frequently as most other charts. So maybe these long intervals have been planned, or at least did not come as a surprise.
Basically, in a nutshell, this question can be re-stated as "Did the latest editions of the Juneau and Dutch Harbor VFR sectional charts prior to the 2-25-2021 update show an 'expiration date' that was earlier than 2-25-21? And if so, why was the previous planned update skipped?"
A note in closing -- The FAA's "Aeronautical Chart Bulletins" webpage is currently a good resource for seeing a list of significant changes that have occurred since the last publication of any given VFR aeronautical chart. Also, as of February 3 2021, this webpage indicated that the Dutch Harbor chart was actually last updated on Feb 27 2020 rather than February 27 2019, so the 2-27-2019 "latest update" date on shown on the "Raster Charts" webpage on 2-3-21 may have been a typo. That doesn't change the basic thrust of this question-- was a planned update in 2020 missed?
PASI on VFR sectional chart, accessed 2-3-21
PASI on LAANC, accessed 2-3-21
  • $\begingroup$ Re "Basically in a nutshell this question can be re-stated as "As of 2-3-21, do the most recent paper editions of the Juneau and Dutch Harbor VFR sectional charts show an 'expiration date' that is earlier than today's date? And if so, why were the planned release dates skipped?""-- this would be referencing the last edition before the 2-25-21 update. $\endgroup$ Mar 1, 2021 at 16:20
    $\begingroup$ Re "The current edition of the FAA's "Raster Charts" webpage lists a March 26 2020 edition for the Juneau sectional and a February 27 2019 edition for the Dutch Harbor sectional. "-- this statement was accurate when this question was posted, Feb 3 21. It no longer is. $\endgroup$ Mar 1, 2021 at 16:44
The FAA has just switched to a 56-day release cycle (double AIRAC cycle) for all VFR sectional charts. In the process of aligning the release cycle, they may have skipped an update. However, the chart of Dutch Harbor was on a cycle of one year before, and would have been due on 25th of February anyway. Juneau was also on a one-year schedule and would have been due on the 25th of March. It is very unlikely that a release would have been skipped.
The story behind the switch to the 56-day release schedule can be found in this FAA briefing. See Milestone #2 below, which may be the reason for skipping a release.
Background/Discussion: The lifecycles of FAA-produced Visual Flight Rules (VFR) Charts vary from 168 days to two years and at one time various charts did not update for years longer (Helicopter and Grand Canyon for example).
Extended and unsynchronized lifecycles create an undue burden on the NAS and on chart users. The NOTAM System must carry many facility NOTAMs until consistently charted. As a result, chart users are burdened with numerous NOTAMS and difficulty arises in identifying pertinent NOTAMs and correctly applying them. Numerous changes are alerted in Chart Supplement Chart Bulletins that many users either do not know exist and/or do not find readily accessible. Unsynchronized chart dates lead to inconsistent data capture on overlapping areas, adjacent charts and other chart products.
Producing 56-day VFR Charts will provide significant relief to a number of these issues. The NAS picture will be consistent with that reflected on Enroute, Terminal and Supplemental products. NOTAMs will be significantly reduced as charts will capture changes with every 56- day AIRAC cycle. Chart Supplement Chart Bulletins will no longer be necessary.
Planned Actions: Update the VFR Sectional, Terminal Area, Flyway Planning and Helicopter Route Chart series on the 56-day AIRAC cycle. Implement this effort across a series of milestones:
Milestone #1 will synchronize the cutoff for VFR Charts with other aeronautical products. (June 18, 2020)
Milestone #2 will eliminate 28-Day AIRAC date VFR Charts to align with airspace amendments and will stage charts for 56-day AIRAC date production. (September 10, 2020)
Milestone #3 will realize full implementation of the 56-day update of VFR Charts and elimination of supporting Chart Supplement Chart Bulletins. (February 25, 2021)
And more history can be found here: VFR Chart Print Schedule Realignment and Synchronization
