71
Could you run a jet with gasoline? Why do all jet engines use kerosene?
  • 31
    $\begingroup$ A better question is why do cars run on petrol rather than kerosene. $\endgroup$
    – Aron
    Mar 5, 2015 at 5:38
    $\begingroup$ Every time I hear people say "kerosene" as jet fuel it just seems weird. I grew up on a farm; I know what kerosene is. It's the stuff you put in a lantern so you can see to go out and milk the cow at night. It's much less volatile than, say, gasoline. It burns slowly and (relatively) cool, which makes it great for a lantern, but--I would imagine--horrible for motor fuel. Is this a different type of kerosene? $\endgroup$ Mar 5, 2015 at 11:13
    $\begingroup$ @MasonWheeler it's the same stuff (take a look at the third paragraph) $\endgroup$ Mar 5, 2015 at 11:47
    $\begingroup$ Military turbine engines are designed to operate on everything from avgas to heating oil but are optimized to run on JP4 / JP5 (roughly the weight of kerosene). If you use one of those other fuels, the engines will require extensive maintenance afterwards. Jet fuel does have a higher energy density than gasoline: en.wikipedia.org/wiki/… $\endgroup$
    – Jim2B
    Mar 5, 2015 at 14:53
  • 7
    $\begingroup$ @raptortech97 - Jet fuel does have a slightly higher energy density than gasoline, both by weight and by volume: 46 MJ/kg and 37.4 MJ/l versus 44.4/32.4 for gasoline (and 48/35.8 for diesel fuel) $\endgroup$
    – Johnny
    Mar 5, 2015 at 20:56
6 Answers 6
103
You can persuade a turbine engine to run on just about anything that can burn. So the decision of which fuel to actually use depends on the side factors including, but not limited to:
  • availability
  • cost
  • emissions
  • hot section temperature
  • chemical reactions with engine parts
Specific examples:
  • Coal dust is rather difficult to pump around, and the rampies don't like shovelling
  • liquid hydrogen (used in the Space Shuttle) requires a lot of storage and has the nasty habit of freezing anything it touches, like rampies.
  • ethylacetylenedecaborane is unpleasantly toxic (rampies union again) and the combustion byproducts were rather abrasive to the engine's innards
  • trimethylaluminum would reduce the engine complexity (no igniters needed) because it has the nasty habit of igniting instantly upon contact with air, so leaks are rather dangerous.
  • natural gas is commonly used as a turbine fuel in pumping stations: it's already there and thus is "free". The required pressure vessels make it impractical to use as an aircraft fuel.
So kerosene basically became the standard turbine fuel because it's:
  • cheap: kerosene makes up a rather large fraction of crude oil. When you measure your fuel load in tons a few cents per litre makes a difference.
  • safe to handle: relatively non-toxic, doesn't ignite all that easily
  • storable and transportable in common structural metals
  • doesn't clog up the engine
  • 60
    $\begingroup$ Couldn't turbines just run on rampies ? $\endgroup$ Mar 5, 2015 at 2:38
  • 56
    $\begingroup$ The larger engines have been known to snack on them occasionally. $\endgroup$
    – paul
    Mar 5, 2015 at 2:51
  • 17
    $\begingroup$ Industrial gas turbines can and do run on just about anything. There's a stream called "refinery gas" which translates to "anything lighter than pentane that the refinery doesn't want & can't store". This includes hydrogen, carbon monoxide, and hydrocarbons. Frequently they are mixed with inerts like nitrogen (mixtures of hydrocarbon and nitrogen are a pain to separate.) The same turbine will be expected to run on kero or gas oil when that is in excess, or for startup. Water is also injected for NOX control. The only issue, as you say, is not to leave a solid residue that will clog the engine. $\endgroup$ Mar 5, 2015 at 8:35
  • 30
    $\begingroup$ Perhaps nice to mention why piston engines are so picky: gasoline should only ignite when you hold a spark to it; diesel should ignite immediately when it's sprayed into a hot cylinder. In a jet engine, fuel is sprayed into apocalyptic burning conditions anyway, so one can have a less 'picky' fuel. $\endgroup$
    – Sanchises
    Mar 6, 2015 at 10:13
  • 12
    $\begingroup$ @sanchises: Gasoline is easier to ignite than diesel or kerosene. The reason spark-ignited engine can only run on gasoline is that the spark would not ignite the heavier fuel at all or it would burn too slowly. In the compression-ignition engine the temperature is much higher so it ignites even diesel. Incidentally this also increases the thermodynamic efficiency (which is why diesels have about one third lower consumption than gasoline engines). $\endgroup$
    Mar 6, 2015 at 13:11
26
In a modern turbofan engine, fuel is not only burned in the engine and used to lubricate parts such as fuel pumps and controls, it is used as a hydraulic fluid as well -- this is used to power things like inlet guide vanes and variable stator vanes in many engines, as well as more exotic accessories such as movable nozzles and inlet ramps.
This means that gasoline is often not tolerated by larger aviation turbines, as it boils at such a low temperature that it could boil off inside fueldraulic (or other fuel system) parts and interfere with their operation, atop the lubricity and lead fouling issues that it obviously would pose. Even wide-cut jet fuels such as JP-4 and Jet-B are prohibited for service in some larger turbofans due to the volatility issues they pose (this is a quote from the 777 QRH Limitations section):
The use of JP–4 and Jet B fuels is prohibited.
From my training, the limits on the PT6 use of avgas is related to its ability to lubricate the engine's fuel pumps, and the lead fouling of the hot section which will result from the avgas. I can't say about other engine's tolerances, but some military jet fuels have much more volatile components than straight kerosene and marine gas turbines run on diesel. A turbine's fuel isn't always decided by what it can burn, but by what it's practical and economic to feed it.
Apologies if this is tangential but other properties of kerosene (aka kerosine) as turbine fuel were brought up. To my knowledge, all "Jet fuels" (intended for aircraft use) are based on kerosene.
Another property of jet fuel that was not mentioned is freeze point where viscosity drops because of wax formation and pumps and filters begin to clog. Ordinary kerosene (as used in lanterns and space heaters) rarely has to deal with sub-zero temperature (e.g. -40C) and 30,000 feet altitude.
Also important is volatility which can be reduced at low temperatures and impede combustion.
see http://www.shell.com/global/products-services/solutions-for-businesses/aviation/shell-aviation-fuels/fuels/types/civil-jet-fuel-grades.html for different fuels and their freeze points.
We ran Olympus Gas turbines for fast power and speeds when I was in the Royal Navy. These happened to be the same turbines that Concord used when she was in service. We ran them on Marine Quality Diesel and had no problems.
Again may be its the - temps could be a real issue, and the fact you get more power from Higher octane fuels, with all the technology these days you would think their would be a cheaper alternative.
    $\begingroup$ Compression-ignition fuels (at least in diesels) are rated by cetane -- as anyone who's had Jet-A put in their avgas drinker will tell you, Jet-A has exactly 0 octane rating! $\endgroup$ Aug 10, 2015 at 23:40
  • $\begingroup$ fantastic info! $\endgroup$
    – Fattie
    Dec 31, 2015 at 14:53
The very high temperatures of jet engines cause gasoline to be a poor fuel because it tends to burn too fast. Kerosene, which is routinely called "Fuel OIL" some places, avoids pre-ignition problems (and some safety hazards) just like higher-octane gas avoids spark-plug knocking. The ultimate control of ignition comes from using Diesel Fuel (which ALSO is routinely called Fuel Oil some places), and that's why big trucks use Diesel: that control gives them the best fuel efficiency their engines can have; but Diesel wont' run a jet engine. Gasoline is too volatile for a jet engine; Diesel fuel is not volatile ENOUGH for a jet.
    $\begingroup$ The problem with running diesel in a jet engine is the igniters -- the SR-71's triethylborane system would ignite diesel no problem! (Diesel won't work in the SR-71 through its envelope for various other reasons, but the ignition system in that aircraft isn't one of them, and I suspect a J58 would run on diesel in an emergency, albeit with a severely limited flight envelope.) $\endgroup$ Mar 6, 2015 at 1:02
  • $\begingroup$ Gasoline's extreme burn rate makes it a poor fuel for a much simpler reason: the difference in burn rates is even more conspicuous in the liquid fuels. A flame will spread over the surface of a pool of gasoline something like six times as fast as over a pool of kerosene, and gasoline also has a much higher vapour pressure and a flash point below most normal ambient temperatures (!). Even Jet B, which is a mixture of kerosene and gasoline, has safety problems due to gasoline's overenthusiasm for catching fire; pure gasoline is far too dangerous to use as jet fuel. $\endgroup$
    – Vikki
    May 27, 2018 at 2:58
