Most commercial jet engines today would be those large jet engines on large passenger craft like a Boeing 747. Can these run on straight ethanol without any problems?
Would more maintenance be required? Would the engine lifetime be reduced? Would it be more susceptible to flameouts or other mechanical risks? Would the airplane never make it off the ground? (I imagine thrust reduction will be limit the takeoff weight.)
One reason I'm asking is because eventually petrol will be gone. (I'm not an apocalyptic saying that will happen next year, but somewhere down the line it will certainly be gone.) Will jet engines require a major redesign, or could they just use ethanol for a few years/decades and be fine?
Note: I'm talking about jet engines (turbofans, but turbojets are okay too), but not piston engines and turboprops.
EDIT: A lot of talk has been generated that ethanol contains less energy than kerosene. I assure you I'm aware of this. Ethanol is like 25 MJ/kg and kerosene is more like 40 or 45. I'm not asking this question with energy efficiencies in mind, but rather out of curiosity if the same engine geometries will work well with both fuels.
A rephrasing: Would current jet engine geometries (blade angles, compression ratios, volumetric flow, etc.) work well with ethanol instead of regular jet fuel?
