Aviation obviously is known for is a.c.r.o.n.y.m.s. and abbreviations.
My question is: who controls the abbreviations/contractions for the below services? If you are aware of a source document showing the contractions I would very much appreciate a link or document name. (edit: USA sources / services).
I have made suggestions in parenthesis for METAR and NOTAMs, but I am not sure if they are the definitive source.
  1. METAR (NOAA / FMH-1?)
  2. TAF (I have no idea, same as METAR?)
  3. NOTAM (combination FAA & ICAO? This doesn't really look like a source document.)
  4. PIREP (no clue)
If I am forgetting any similar services which also use acronyms I would appreciate a heads-up so I can add to the question!
Thanks for your time.
  • $\begingroup$ What is the purpose of this list? Once you know that the METAR format is controlled by the World Meteorological Organisation with exceptions for North America (WMO and FMH-1), what are you going to do with this?. Other countries may have their own exceptions, and countries not signed up to the WMO may do their own thing. Do you want to cover all those as well? $\endgroup$ Commented Dec 4 at 21:46
  • $\begingroup$ Purpose of list: I want to know where to look for primary sources. What I will do with list: read the primary sources. I am only asking about USA sorry for ambiguity. $\endgroup$
    – codenoob
    Commented Dec 4 at 22:09
    $\begingroup$ @CatchAsCatchCan "Why do you want to know?" is a strange thing to ask on a website devoted to answering peoples' weird questions. $\endgroup$ Commented Dec 5 at 21:56
Who controls?
Meteorology and aviation are fields impacting all countries, and where phenomena and aircraft cross State boundaries. Activities in these domains require an international collaboration and harmonized practices. The United Nations organization is made for that. Each UN State member has representatives in UN agencies to provide inputs and agencies issue recommendations and standards that can be implemented in the State members local regulations.
In the US, FAA is the US agency for aviation matters and NOAA the agency for weather matters. They work with their counterparts in the corresponding UN agencies: ICAO and WMO.
This collaboration is similar to the collaboration between ICAO and ITU, another UN agency, in the domain of radio spectrum use, radio transmission standards and navaids.
Aeronautical reports and forecasts
Aeronautical reports and forecasts are defined jointly by two agencies of the United Nations:
The two key documents for weather codes are:
The last one is likely the one you need to decode some cryptic weather message quickly.
Other WMO relevant documents, also available online, relate codes and practices to the general meteorological field, e.g. different manuals on codes, like WMO Manual on Codes, Alphanumeric Codes (human readable form, sort of) and Manual on Codes, Binary Codes (data storage and exchange).
ICAO ensures meteorological services standardized by WMO are adequate for aviation. Related formats include forecasts:
  • $\small \sf WAFS/SIGWX$: Global forecasts of significant weather,
  • $\small \sf TAF$: Aerodrome forecast,
  • $\small \sf GAMET$: General aviation forecast,
and reports:
  • $\small \sf METAR$: Aerodrome routine meteorological report,
  • $\small \sf SPECI$: Aerodrome special meteorological report,
  • $\small \sf VOLMET$: Meteorological information for aircraft in flight,
  • $\small \sf SIGMET$, $\small \sf AIRMET$: Specified en-route weather phenomena.
Aircraft-based observations: PIREP, AIREP, AMDAR
Originaly a PIREP (pilot report) is an informal radio report from a pilot to ATC. Methods and codes are mostly defined by the national aviation agency, FAA for the US. See the FAA PIREP form. Some information is provided in WMO Guide to Aircraft-based Observations.
However with the advent of automated sensors in aircraft, formatted and automated reports are defined as AIREP (special air report) and AMDAR (aircraft meteorological data relay) messages, transmitted using ACARS or ASDAR. Both reports are described in ICAO Doc 8896, Manual of Aeronautical Meteorological Practice and WMO Guide to Aircraft-based Observations, both already mentioned.
NOTAM
NOTAM (notice to air missions) is a different kind of information. an important part of the aeronautical documentation, describing information which cannot be permanent, and thus cannot be included in the regular State aeronautical information publication (e.g. US AIP). They are standardized by ICAO in Annex 15, Aeronautical Information Services
Technical details are found in Doc 10066, Aeronautical Information Management (PANS-AIM) and Doc 8126, Aeronautical Information Services Manual.
    $\begingroup$ I know comments arent supposed to be used for "thanks" but there are a lot of good resources you put in here. So... thanks! $\endgroup$
    – codenoob
    Commented Dec 15 at 2:24
