How can I describe this sky, in 3 letters as per the Aerodrome actual weather - METAR decode?
I found online a comprehensive list of Metar codes
    $\begingroup$ Looks like Broken (BKN) to me, but you also need to provide base altitude, so just BKN doesn't accurately describe the picture. $\endgroup$
    – Ron Beyer
    Oct 26, 2016 at 14:03
This work sheet may be of use and generally the system of Okta is used to denote coverage in a Metar, but I would say
L1 Clouds: Cumulus (Cu) with little vertical extent
but it could also be
L5 Clouds: Stratocumulus (Sc) not from spreading out of Cumulus (Cu)
But I will agree with Ron on this one, its BKN (5-6 Okta based on the picture in my opinion)
  • $\begingroup$ Looks scattered to me $\endgroup$ Oct 26, 2016 at 17:47
