For an airport to be designated as an IFR alternate, does it have to have a terminal aerodrome forecast at the alternate airport to confirm that the forecast 600-2 and 800-2 will be in place at the time of arrival?
3$\begingroup$ Welcome to aviation.SE! I'm assuming you're asking about FAA regulations, but are you asking if a) the forecast conditions you mentioned are required, or b) what the acceptable ways are to get the forecasts (e.g. TAF)? $\endgroup$– PondlifeApr 25, 2019 at 4:44
1 Answer
tl;dr You don’t need to have a TAF at the alternate and can use other sources of weather.
Keep in mind that there are two reasons that an alternate is required. First is to assure that the pilot has evaluated the weather at the destination and considered what to do if the destination is unavailable. Second is to let ATC know what the pilot intends to do if they lose communication. In the modern ATC system, with near universal radar coverage, that isn’t as much an issue as when the regulations were written.
In the US, the destination and alternates must comply with 91.169. It specifically says that there must be weather reports or weather forecasts for the airport. Normally when you flight plan you would rely on the Terminal Area Forecast to determine whether the weather one hour before and one hour after the estimated time of arrival at your destination is above the minimums. If that is not the case then an alternate is required. And again you would rely on the TAF for the forecast.
However, TAFs are not the only way to get a forecast. NOAA publishes Graphical Forecasts for Aviation and if the weather for the area is above minimums, you could use that as a means of satisfying the requirement.
Here is an example where the coastal forecast is below minimums but the airports inland will be VFR.
Or you could look at airports around the alternate and if they are above minimums, then your alternate would be as well. In the TAFs below, there are lots of airports that inland that do not have TAFs but that you can surmise that they will be VFR.
In practice, picking an airport with a TAF as an alternate is much easier. There is no requirement that you actually go to the alternate if you can’t make the destination. And with ADSB-In, you can monitor the weather while you fly, so you have a much better idea of what the weather is doing at your destination. You can divert to an alternate at any time it doesn’t look like the weather at your destination is below your personal minimums.
§91.169 IFR flight plan: Information required.
2) Appropriate weather reports or weather forecasts, or a combination of them, indicate the following:
(i) For aircraft other than helicopters. For at least 1 hour before and for 1 hour after the estimated time of arrival, the ceiling will be at least 2,000 feet above the airport elevation and the visibility will be at least 3 statute miles.
(c) IFR alternate airport weather minima. Unless otherwise authorized by the Administrator, no person may include an alternate airport in an IFR flight plan unless appropriate weather reports or weather forecasts, or a combination of them, indicate that, at the estimated time of arrival at the alternate airport, the ceiling and visibility at that airport will be at or above the following weather minima:
(1) If an instrument approach procedure has been published in part 97 of this chapter, or a special instrument approach procedure has been issued by the Administrator to the operator, for that airport, the following minima:
(i) For aircraft other than helicopters: The alternate airport minima specified in that procedure, or if none are specified the following standard approach minima:
(A) For a precision approach procedure. Ceiling 600 feet and visibility 2 statute miles.
(B) For a nonprecision approach procedure. Ceiling 800 feet and visibility 2 statute miles.
1$\begingroup$ Very interesting, I didn't realize that "weather reports.....that indicate conditions will be" was the wording. In theory you could look at the current conditions, discover that it's severe clear for 300 miles, and launch without ever looking at a "forecast". Thanks for this! $\endgroup$– Steve V.Apr 25, 2019 at 18:12
