I understand the difference between a compressor stall and surge.
Stall: One or two blade stages exceed the critical AoA, the airflow is turbulent, and the smooth airflow through the compressor is disrupted
Surge: Occurs after a compressor stall where most or all the blade stages are affected from it, there’s a complete disruption of airflow through the compressor and restricts airflow to the engine.
A stall produces a big bang, flames at the back and sometimes in front of the engine due to flow inversion, and severe vibrations and engine damage in a severe stall. In the cockpit we can see fluctuations in RPM and raise in EGT.
But what noises/indications a pilot from the cockpit would hear/see in a compressor surge? Are they similar?
