One of the constant problems of aviation is drawing onto the center line on final. Either due to a bad rollout or due to crosswinds a pilot often finds that the aircraft is not on the center line for landing. If the aircraft is far off the line, we can end up doing buttonhook turns and other dangerous maneuvers to get on line.
I am wondering about the viability of side slipping onto the line instead of doing banking maneuvers. In other words, there would be no bank and no turn. You would side slip and add power to maintain altitude, thus theoretically that would just slide the aircraft onto the line. This seems like a potentially more reliable and controllable way to adjust an aircraft onto the center line during final. What is the viability of this maneuver?
It seems to me there is a logic to it, because when I am dealing with heavy gust conditions this is basically what we are taught to do anyway: you put the windward wing down and side slip into the crosswind as you land to keep a level attitude. So, we are often doing this maneuver anyway, why not use it adjust to center on final?
    $\begingroup$ Yes, but somehow it's OK to do it when there is a crosswind component? Really depends what you're flying. I was actually waiting for a 3 degree powered approach with huge wings to chime in. There one can yaw and use the thrust component to hold line. This helps avoid wing strike. Flying a good pattern is important in all cases. $\endgroup$ Jan 22, 2022 at 11:30
  • $\begingroup$ Sideslip will not move the aircraft laterally. It only changes the direction that the nose is pointed in, it does not initiate a turn (a change in the direction of the flight path/ground track). So by itself, it cannot put your ground track on the center line if it is not already there. All it can do is align the nose direction the nose is pointed in (and. more significantly, the main gear wheels and tires) with the centerline. That is only one part of the problem. You also need to ensure that the ground track is aligned with, and over, the centerline. $\endgroup$ Jan 22, 2022 at 17:02
    $\begingroup$ In my opinion routine use of a side-slip to establish your airplane on the centerline of a runway from a base to final turn or on a long final (as opposed to a crab) is an extremely poor practice. A side-slip should be used to align your airplane with the centerline on a very short final (perhaps 50 ft agl or so just prior to a flare) in a crosswind or occasionally (as a forward-slip) to lose altitude on final. Certainly contrary to a "stabilized approach" concept. Just my opinion. $\endgroup$
    – user22445
    Jan 22, 2022 at 18:32
    $\begingroup$ @CharlesBretana please review "side slip" and "forward slip". "Side slip" is the one for lateral movement. Remember, lift is by far the most powerful force an aircraft produces, why not use the horizontal component to move sideways? (banking). $\endgroup$ Jan 22, 2022 at 20:17
    $\begingroup$ @RobertDiGiovanni The most powerful force an aircraft produces is the force ejecting money from your wallet. $\endgroup$ Jan 22, 2022 at 20:54
4 Answers 4
I’m not totally sure how you’re orienting that, are you talking about aligning the aircraft up on final approach from a base leg, then doing a slip to final alignment on the runway CL for final approach?
The best way to get the aircraft aligned on runway centerline during the base to final turn, is to note where the runway will centerline will intersect the base leg flight path if it were extended out that far, thence plan your turn from base to final to roll out on that imaginary centerline without being rushed or overshooting. In addition a pilot may opt to fly a crabbed final approach as opposed to a side slip. As the pilot enters the round out, they should use rudder pressure to align the long axis of the airplane parallel to the centerline and aileron pressure to hold the airplane on centerline with the main wheels straddling the CL.
NOTE WELL: if your airplane over shoots or under shoots runway centerline during the base to final turn, you feel rushed in the turn, or have to use some sort of gross maneuver on final to get the aircraft position back on center line, you should immediately perform a go around as opposed to continue to force the airplane to fly final in land.
  • $\begingroup$ "As the pilot enters the round out, they should use rudder pressure to align the long axis of the airplane parallel to the centerline and aileron pressure to hold the airplane on centerline with the main wheels straddling the CL." -- just curious-- are you talking about only in the presence of a definite crosswind, or also just to counteract small random sideways drifts or pilot errors/ oversights-- say you are landing in calm winds and as you are just starting to round out from final approach you notice you are 3 feet left of centerline, do you use this technique? $\endgroup$ Feb 6, 2022 at 13:15
  • $\begingroup$ If so it seems the answer to original question (apart from the part about zero bank angle which is not possible) would be "yes, at least for small corrections near the ground". $\endgroup$ Feb 6, 2022 at 13:16
Side slipping to the center of the runway is an excellent technique for high wing aircraft (with minimal risk of a wingtip strike). One might correct a base to final overshoot with a coordinated turn. Once on the final glidepath, finer adjustments can be made by sideslipping.
Generally, it is not a good idea to combine uncoordinated flight with a turn, but the side slip is much safer than skidding with excess rudder.
Adequate airspeed, and practice at altitude, is essential in keeping low and slow manuvering safe. One can stay coordinated, and not slip until after rounding, and some prefer to side slip (using opposite rudder) higher up on final once the aircraft has completed its turn. This has the advantage of lining the nose up with the runway earlier. Others come in on a circle, controlling rate of descent by side slipping (varying bank angle). So, one can side slip with more power for lateral movement, or simply "drop a wing" to bleed off a few feet of altitude.
The technique is known and widely used. Safety will depend on knowing the limitations of the model of aircraft being flown.
Viable to slip onto the center line?
Yes, we can use a sideslip to shift the aircraft sideways relative to the runway, without changing heading. More on this below. However, the body of the question contains some misconceptions--
This excerpt shows a misunderstanding of basic flight dynamics. The fundamental characteristic of a sideslip is that the aircraft is moving sideways through the air. As an aircraft enters a sideslip, there's generally going to be a bank, a turn, or both.
If rudder is applied and held while the ailerons are manipulated as needed to keep the wings level, the aircraft will fly sideways through the air (sideslip), and the aerodynamic force resulting from the air striking the side of the fuselage will cause a curvature in the flight path-- a turn-- in the direction of the deflected rudder. So now we're actually in a skidding turn.1 The aircraft's heading will change. You could steer the aircraft closer to the runway centerline this way, but why would you? Much better to turn the normal way-- by banking. Skidding turns are generally considered to be bad airmanship, and an invitation to a spin.
On the other hand, when we talk of "sideslip" we often envision a maneuver where the aircraft is kept in a bank opposite the direction of the rudder input. For a typical "forward slip" to increase the descent angle and sink rate, we would apply rudder, moving the nose to a different heading and exposing the side of the fuselage to the airflow, while simultaneously applying bank as needed to provide a sideways force that cancels the aerodynamic sideforce from the sideways airflow striking the fuselage, preventing the flight path from curving in the direction of the applied rudder. So we're now flying sideways through the air, but the direction of the flight path and ground track hasn't changed-- this won't bring us any closer toward the runway centerline.
Alternatively, we could first apply the bank angle, while manipulating the rudder as needed to prevent any heading change at all. This is the typical "sideslip" that we do to compensate for a crosswind on final approach. Aerodynamically, for any given bank angle, this kind of "sideslip" ends up being exactly identical to the "forward slip" described immediately above-- we've just entered it slightly differently, giving the flight path and ground track some time to change direction (toward the low wing) before the full rudder correction is applied.2 So we've actually accomplished a turn as we entered the maneuver-- we've angled or "bent" the direction of the flight path and ground track toward the low wingtip.3 Once the maneuver is stabilized, with constant bank angle and rudder deflection and heading, the flight path and ground track are linear again, but no longer aligned with the aircraft centerline (at least in the no-crosswind case). The fuselage ends up moving sideways through the air, like in any other sideslip.
We could use this maneuver to move toward the runway centerline without changing heading. (Not to move toward the runway centerline without banking.) And for small corrections, this may be in fact what pilots sometimes (perhaps unconsciously) do, especially when very near the runway. Of course, the wings should be leveled again (in the no-crosswind case) to stop all sideways "drift" before touchdown-- touching the ground while moving in a different direction than the aircraft is actually pointing can be hard on the landing gear. For larger corrections, carried out higher from the ground, it's generally better just to do a shallow turn toward the centerline, "coordinated" in the usual manner.
For completeness, we should also note that in the case described immediately above, when we remove the bank and the rudder input to exit the sideslip, without allowing the aircraft to change heading, we again accomplish a "turn"-- we "bend" the direction of the flight path (and the ground track, in the no-wind case) so that they are again parallel to the direction the aircraft's nose is pointing. Technically, this could be described as a very slight "skidding" turn-- as we are taking out the bank angle, we delay taking out the rudder input for just long enough to allow the sideforce from the air striking the side of the fuselage to "bend" the flight path and ground track in the direction of the deflected rudder (i.e., toward the high wingtip.) You'll never see this maneuver analyzed in this level of detail in any flight training materials--and knowing this extra detail won't make your landings any better-- but that's in fact what is going on. From the pilot's viewpoint, however, it's simpler just to focus on the fact that by banking the wing, without allowing the heading to change, the aircraft is being "slid" sideways toward the low wingtip, and this "sliding" ends once the bank is removed.4
Footnotes--
  1. The language gets kind of complicated here. To an engineer, any sideways motion of the aircraft through the air is a form of a sideslip. To a pilot, if the sideways motion is toward the high wing, or if the wings are completely level, the maneuver is called a "skid" rather than a "slip" or "sideslip".
  2. This, in a single sentence, is the slight difference between the control inputs used to enter the maneuvers commonly described as a "sideslip" and a "forward slip". Pertains to many other ASE questions -- such as this one: What is the difference between a forward slip and a side slip? . No suggestion is intended here that a pilot is typically aware that he or she is doing something slightly different with the rudder when entering a forward slip versus a sideslip-- it's just a natural result of the pilot's intention to either keep the aircraft's heading constant during the entry, or to cause it to change.
  3. Of course, the "turn" we're talking about here is quite modest-- for the aircraft heading to stay constant, the direction of the flight path through the airmass must "bend" or change by an angle that is exactly equal to the angle between the direction of the flight path through the airmass and the direction the centerline of the aircraft is pointing. I.e., by an angle equal to the yaw string deflection, in the case of a "perfect" yaw string mounted on a long probe well in front of the nose of the aircraft.
  4. This simplification-- focussing on the sideways "sliding" aspect of the maneuver while ignoring complete dynamics of the actual turns that take place as the maneuver is initiated or terminated-- arguably has tinges of an Aristotelian rather than Newtonian understanding of physics-- one can easily draw the incorrect conclusion that a steady net force is required to cause a steady linear motion.
  • $\begingroup$ Really I suspect that most pilots are not fully aware of exactly how they control an aircraft in the last few tens of feet of altitude before touchdown $\endgroup$ Jan 23, 2022 at 14:10
  • $\begingroup$ Every one please read footnote 1. $\endgroup$ Jan 23, 2022 at 15:25
Sideslip will not move the aircraft laterally. It only changes the direction that the nose is pointed in, it does not initiate a turn (a change in the direction of the flight path/ground track). So by itself, it cannot put your ground track on the center line if it is not already there. All it can do is align the direction the nose is pointed in (and, more significantly, the direction that the main gear wheels and tires are pointed in) with the centerline. That is why we use this for crosswind landing, to minimize the sideload forces on the landing gear.
But that is only one part of the landing problem. You also need to ensure that the ground track is aligned with, and over, the centerline. Flying the aircraft so that it is over the runway centerline is simple. When the runway, (and the centerline) appear to be absolutely vertical in the windscreen, you are over the extended centerline. Aligning the aircraft ground track with the extended runway centerline is accomplished by keeping it that way (vertical). If the runway centerline "picture", as you fly down final, twists in the windscreen so that the near end is moves to the right, you are drifting left of centerline, you need to move the aircraft back to the right. If the near end moves to the left, you are drifting to the right, and you need to turn the aircraft and move right.
In practice, if you consciously look for this, and monitor it, this is absurdly simple and easy. If you are not looking for it, you will not be aware of it.
  • $\begingroup$ Comments are not for extended discussion; this conversation has been moved to chat. $\endgroup$
    – Jamiec
    Jan 24, 2022 at 9:38
