I have read a320's optimum CG position is 25% MAC. But, the aerodynamic center is also at 25% of chord. So since CG and aerodynamic center at the same position, there would be no moment arm of lift, so what will be the use of tail plane? Also, as fuel burns, the CG shifts rearward, in that case aerodynamic center will be in front of center of gravity. wouldn't that mean center of gravity is behind the center of pressure? I have read center of gravity is ahead of center of pressure in airliners, so wouldn't this be a violation. Please explain my two questions.,
  • $\begingroup$ Fly by wire baby~ $\endgroup$ Dec 3, 2019 at 20:28
  • $\begingroup$ Without a tail plane how would you control pitch? $\endgroup$ Dec 3, 2019 at 21:48
I do not know much about the specifics of the A320 design, but I will try to come up with some general answers to your questions.
Even if it was the case in the A320 that the CG and AC coincide (I do not know), it does not mean that there is no moment from lifting forces. The aerodynamic center is not the point of zero moment, it is the point of constant moment within reasonable angles of attack. Hence there will be a moment from the lifting force. Assuming CG and AC coincide, the moment generated by lift will not change the total moment on the aircraft. Therefore a stabilizer is still required.
Not necessarily. The center of pressure is usually for most angles of attack behind the aerodynamic center. Therefore, under the assumption that the CG and AC coincide, the CG can move aft of the AC and still be in front of the center of pressure.
Center of pressure movement as function of angle of attack
