Is it true that when flying a non-precision approach flying the CDFA - Continious Descend Final Approach Technique can or shall be used. This allows to treat the MDA as a DA meaning you fly down to a DA and take the continue / go-around decision like in a precision approach, or the MAP - Missed Approach Point, whichever is earlier? In a step down non-precision approach the MDA must not be crossed below and a Missed approach must be executed no later than the MAP. So is it true that technically you will go slightly below the MDA when flying the CDFA technique as the decision is taken at that point not the actual go around meaning you could lose 50ft during that manoeuver. Is it a legal requirement to add a increment to the MDA in that case this is a debate I am having. I have not found anything in the EASA CAT or FAA FAR that require an increment to the MDA/DA when flying the CDFA technique or am I wrong? Nevertheless in the ATPL manual I read I came across the following part when flying GNSS Approaches:
Does such an increment even exist? Is it an actual procedure to add 50ft or an increment to the MDA/DA when using the CDFA technique or not? I have not found anything like this in the SOP of an airline. Technically there would have to be a table for different airplanes, because 50ft would be too generic. Is it done in FAA or EASA is there a difference maybe that I am not aware of?
Following I found in the ICAO DOC. 8168
