12
What is the oldest aircraft still in production? I Googled it but only got the answer to the oldest military aircraft still in production.
  • $\begingroup$ Do you mean oldest type with a continuous production run, or the oldest design still being hammered together? $\endgroup$
    – egid
    Commented Nov 3, 2014 at 15:34
  • $\begingroup$ @egid the answers to both would be interesting. ;) $\endgroup$ Commented Nov 3, 2014 at 15:52
  • $\begingroup$ @egid also, if production only paused for about ten years or so I would count it $\endgroup$ Commented Nov 3, 2014 at 15:55
  • $\begingroup$ Well, given aviation's occasional financial... issues, what is in production today might not be tomorrow. ;) $\endgroup$
    – egid
    Commented Nov 3, 2014 at 16:13
  • $\begingroup$ Shouldn't the Piper Cub be considered a candidate? At least if you allow variations/improvements on a basic design... $\endgroup$
    – jamesqf
    Commented May 7, 2016 at 5:48
4 Answers 4
18
Longest production run (civil)
The Beechcraft Bonanza seems like a likely candidate for 'oldest design still being made'; first flight was 1945, and it's still in production today (albeit made by the same parent company that makes Cessnas!). Even during the general aviation downturn in the US of the 1980s & 90s, production continued, as Kevin Cathcart pointed out in the comments:
FAA registrations show no gap in years of manufacture of the A36 Bonaza. I was able to find a registration for one manufactured in every year from 1980-1999 in california alone. Production did drastically slow during that time frame, but it never stopped.
B35 Bonanza via wikimedia
Longest production run (military)
The Lockheed C-130 Hercules military transport first flew in 1954 and has been in continuous production ever since. According to Wikipedia, they've even been built in the same factory (in Marietta, Georgia) the entire time.
C-130 prototypes, via Wikimedia
Because only around 2,300 have been produced (only!), they don't show up on the 'most produced aircraft list' mentioned in another answer.
    $\begingroup$ FAA registrations show no gap in years of manufacture of the A36 Bonaza. I was able to find a registration for one manufactured in every year from 1980-1999 in california alone. Production did drastically slow during that time frame, but it never stopped. $\endgroup$ Commented Nov 7, 2014 at 17:12
  • $\begingroup$ Incorporated that into the answer. Thanks, I didn't even think to check the aircraft database! $\endgroup$
    – egid
    Commented Nov 7, 2014 at 17:16
I don't know if it counts, but the Messerschmitt Me-262 has seen a second production run of five aircraft being finished earlier this century after approx. 1500 had been built before the middle of the last, from 1941 - 1945. The new production was started in 1993 by the Texas Aircraft Factory, led by someone who had learned metal aircraft craftsmanship as an apprentice in Germany during WW II and who later moved to the US. The job was finished in Seattle by ex-Boeing people, and the aircraft were rivet-for-rivet copies from the original design, with one exception: They are powered by J-85 engines instead of the old Junkers 004B. The Junkers jets were similar in size and mass to the EJ 200 of the Eurofighter, but with 1/7 of the thrust and just 50 hours between overhauls were considered a liability.
Already in 1950, in the early phase of the Korean war, a new series of the Me-262 was briefly considered when US aircraft found themselves to be outclassed by Soviet-built jets. In the end, the Me-262 wing design heavily influenced that of the North American F-86 Sabre.
The Great Lakes 2T1A biplane trainer was designed during the roaring 20s and first flew in 1929. While there were many gaps in production over the years as the company and plans changed hands, it is currently in production - a design close to 90 years old!
A gander on the list of most produced aircraft on Wikipedia suggests the Cessna 172 which started production in 1956 and is still produced today.
However the Aeronca Model 7 Champion has returned to production in 2007 after a short production run from 1945-1950.
  • $\begingroup$ Does anyone know if the 172 has been in continuous production (i.e. at least one manufactured in each consecutive calendar year) since '56 - I assume it has. $\endgroup$ Commented Nov 3, 2014 at 9:57
  • $\begingroup$ @RedGrittyBrick "Production halted in the mid-1980s, but resumed in 1996 with the..." $\endgroup$ Commented Nov 3, 2014 at 10:24
    $\begingroup$ @ratchetfreak yeah, same goes for the Beechcraft Bonanza, which is actually about 10 years older than the 172. Basically all US GA production ceased during the Great Legal Nightmare. $\endgroup$
    – egid
    Commented Nov 3, 2014 at 15:33
