I'm a private pilot (in the U.S.) and I was doing hood instrument training with my instructor under VFR. I put on the hood and we did an instrument takeoff, and I flew up to 4,500 feet to do some VOR holding pattern practice, all while under the hood. We were in a Class C airspace. At 4,500 feet I peeked out from under the hood, and to my astonishment we were surrounded by thin wispy clouds. I think we even flew through one and couldn't see outside the airplane. It looked to me that we were obviously in violation of VFR cloud clearance requirements because the clouds were less than 100 feet from the plane and we flew through some of them. I said this to my instructor, and he insisted that we were still VFR and that I should get back under the hood and continue the holding procedure. I insisted again that we were clearly in violation of VFR cloud clearance requirements, and he again insisted that we were fine and we should keep flying. After three or four times he finally conceded, and we descended and did some practice instrument approaches while clear of clouds.
On the ground after the flight, my instructor said that the clouds were "scuds" or clouds just beginning to form, and that they were see-through. I'm a little shaken by this because I've worked with this instructor for a year and a half and I haven't seen any reason not to trust him, but I feel a little betrayed by this. My instructor is probably in his 60s and has been flying and instructing for many years. If I'm wrong and we were legal to fly through the scuds VFR then I'll admit that, but it seems to go against my education. Maybe pilots normally fly through scuds with no problem, and if that's common practice for pilots then I guess I'll do that. But if he let us fly into clouds illegally and then insisted that we keep flying, I'm a little shaken by that because I've worked with him for a long time and he seems to be a good instructor. I'd like some clarification on this.
    $\begingroup$ Please specify your jurisdiction $\endgroup$ Feb 16, 2021 at 7:30
    $\begingroup$ This seems familiar-- haven't we had a question like this before? $\endgroup$ Feb 16, 2021 at 12:15
    $\begingroup$ Does this answer your question? Are VFR pilots required to avoid an isolated cumulus cloud like any other cloud? $\endgroup$
    – Pondlife
    Feb 16, 2021 at 17:17
  • $\begingroup$ Pondlife - no it doesn't. It sounds like getting close to clouds is technically illegal but pilots do it all the time and it's no big deal. $\endgroup$
    – SurfandSky
    Feb 16, 2021 at 17:25
    $\begingroup$ @SurfandSky Perhaps I misunderstood your question. I thought you were asking about regulations ("violation", "legal", "requirements") but are you really asking if pilots routinely ignore those regulations in practice? Or are you asking if a cloud is still a cloud if you can see through it? $\endgroup$
    – Pondlife
    Feb 16, 2021 at 18:00
From a preponderance of caution, my gauge on clouds is that if you can not see through them to fly by reference to the ground or the natural horizon, it is a cloud. And, a cloud, by any other name (scud, wisp, fog, etc.), is still a cloud. It will obscure visibility.
The question that you have to ask yourself is, “What is the purpose of VFR cloud clearance?” Were you able to see and avoid an aircraft if conflicting traffic was present? Would another aircraft be able to see and avoid you?
Like your instructor, I have flown for forever, and been a CFII for all but 3 of those years. The test I have always applied, is:
"If you can see through it, it is not a cloud."
In other words the cloud must be opaque as viewed.
However, as in many things, it may not be so simple. One might reference: How do the FAR's define a cloud??
