I will be interested to know what was the lift-to-drag ration for a few more known WWI biplanes at take-off, cruise and landing speed; with the propeller running, stopped or non existent (tests in wind tunnels).
$\begingroup$ It'll be tough to find that unless you rummage around university study archives or find some old NACA reports. It's easy to give a ballpark figure. Reasonably clean monoplanes are generally 8:1 to 11:1. A flying barbwire fence like a WW1 biplane would range from 4:1 to 7:1. $\endgroup$– John KOct 13, 2020 at 15:32
$\begingroup$ @JohnK I'm looking at Wikipedia. Maybe I could infer the value from the specs? $\endgroup$– AbdullahOct 13, 2020 at 15:35
$\begingroup$ I don't think you could. You would have to be able to work out the glide angle at different speeds, and so you'd have to have the sink rate at a given speed. $\endgroup$– John KOct 13, 2020 at 15:44
$\begingroup$ @JohnK well, what i was trying to do was get the thrust/weight then reciprocal. You know, get a lower bound value? $\endgroup$– AbdullahOct 13, 2020 at 16:03
1 Answer
AE Berriman published his respected survey of Aviation in 1913. At that time drag was known as resistance, with other terms such as head resistance or drift also used. He discusses the lift:resistance ratio only with respect to aerofoil design.
It is unlikely that the l/d of the whole aircraft was ever considered quantitavely as a useful number. One might gain some idea by looking at Farnborough wind tunnel results for propeller thrust at given airspeed and RPM, and then comparing those with aircraft fitted with that propeller, but that would have been of little value in a hectic war and would not have been done. Of more use was the relative speeds of different types when given the same engine and propeller, or of a given machine when fitted with a new propeller.
Pilots would have had some idea of how far their machines would glide when the engine failed, as happened often enough, but only hazy notions of actual speeds and sink rates. They would also have struggled with the fact that the gliding speeds and angles for minimum sink rate and maximum distance were different.
With hindsight we can make guesses. Glide slopes remained well below 1:10 until the German soaring gliders of the 1920s. Airspeeds were slow, around 100 mph, so thrust and drag were not as high as might be expected today. While engines had relatively poor power-to-weight, airframes were so light they would sometimes break up under the extreme manoeuvres of combat. A steep gliding angle of say 1:4 would have required an unrealistically powerful engine to generate thrust (nominally) equal to a quarter of the gross weight, so wings were relatively large and lightly-loaded to give better lift at lower speeds.
So I'd hazard that around 1:5 to 1:8 would have been the norm. If anybody knows of a better-researched analysis, I would be delighted to be proved wrong.
