The normal shock relations (seen below) are derived by using steady, 1D, neglect potential, no shaft work, adiabatic and zero viscosity assumption. However, since shock waves are "thin regions of high velocity and temperature gradients, where, friction and thermal conduction play an important role," (Anderson, Fundamentals of Aerodynamics) why is the assumption of zero viscosity correct?
Normal Shock Relations (Zucker, Fundamentals of Gas Dynamics)
While I know that the normal shock relations give the correct answer, I am unsure of why neglecting friction is justified and does not lead to inaccuracies.
Neglecting friction does indeed lead to inaccuracies. Those, however, are small for weak shocks, so using the equations for inviscid shocks gives a good approximation. Especially in the times before electronic computers, this was a major simplification while the error was tolerably small.
Stronger shocks should be avoided and replaced by a cascade of weaker, oblique shocks in order to minimize losses, so for practical work there is little need for equations which include those losses. Only in academic work and the design of reentry vehicles with their blunt geometries would the precise calculation of stronger shocks be of any interest.
But how large are those losses? Wikipedia has a page on normal shock tables and the last column gives the ratio of the stagnation pressures ahead and past the shock. Since both should be the same in case of a lossless shock, the real number gives a good approximation of the energy losses incurred over the shock. The more the result deviates from 1, the bigger the losses. 1% of stagnation pressure is lost at a Mach number ahead of the shock of approximately 1.225. 10% is lost at Mach 1.587. It goes down from there: 50% is lost at Mach 2.5 and 90% at Mach 4.4. All values use a ratio of specific heats of 1.4, so they are valid for a two-atomic gas (or a mixture of predominantly two-atomic gasses like air).
  • $\begingroup$ If neglecting friction leads to inaccuracies, and strong shocks have are especially problematic, shouldn't neglecting friction for normal shocks (which are always strong since the Mach number after the shock is subsonic), always give inaccurate results? Also, what order of magnitude is this error? Any citations on this inaccuracy? $\endgroup$
    – Nick Hill
    Dec 12, 2019 at 16:10
  • $\begingroup$ @NickHill: Straight shocks only are strong when the Mach number is significantly above 1. For the losses, please see the Wikipedia page on shock tables. I added that information to the answer. $\endgroup$ Dec 12, 2019 at 17:36
