I am currently running CFD cases on a transonic airfoil at Mach 0.75 and performing an angle-of-attack sweep to evaluate its performance. When I reached the angle of attack of 4.5 degrees (which I appreciate is very high for transonic flight, but tested nonetheless), a dual shock was formed on the suction side. Is this physically possible?
I understand how the suction-side flow may reaccelerate after a shock with favourable pressure gradient and possibly exceed sonic again, leading to a second shock, but wouldn't it just produce a single, stronger shock downstream?
I attached the two flowfields, colored by Mach number, with the first image representing the angle of attack of 4.5 and the second at 3.5 degrees.
Following jayS answer, I plotted the Cp for the two airfoils seen above, for comparison to the chart found.
