If there is a flameout on the F-16 in the air, what is the procedure for restarting it?
I'm sure this is an elaborate checklist, so I'm only asking for an overview of the key parts, especially I'm interested in to what extent the pilot has to manually operate this process.
Is it required to manipulate fuel? Ignition? Temp? Air source? Does it involve the JFS system? Battery?
This https://www.quora.com/How-do-you-start-the-engine-on-an-F-16-Fighting-Falcon provides a nice little overview of how to start an F-16, with some pictures. However, it doesn't explain exactly how the engine is ignited in the first place. JFS, then engage throttle to allow fuel in, and magically it ignites? Surely it doesn't ignite just from pressure alone when driven by the JFS? It feels like a crucial step is missing in that overview and that step would probably allude to how to restart the engine.
It seems that in the event of a flameout, on at least block 50 F-16's Can fighter aircraft glide? the EPU (Emergency Power Unit) kicks in which provides power and hydraulics. Prior to this, the battery supplies power (but I imagine it must be turned on manually, as there is a switch for this!) and the hydraulics appear to work for some time even without the EPU, JFS or the main engine.
However, I know nothing about how the engine actually gets restarted. What does the pilot need to do, and why?
As a bonus question: Why doesn't this guy attempt to restart the engine? Did they already try, and give up?
  • 7
    $\begingroup$ First, press Ctrl-Alt-Del... $\endgroup$
    – Vikki
    Apr 12, 2019 at 2:48
  • $\begingroup$ I'm sure the pilot did try to restart and could not due to a mechanical failure or had run out of fuel, you'd never glide land a fighter voluntarily. $\endgroup$
    – GdD
    Apr 12, 2019 at 9:07
    $\begingroup$ Wasn't there an F-16 crash recently? I guess quicker answering is required here... :) $\endgroup$ Sep 29, 2019 at 18:45
    $\begingroup$ @rackandboneman Belgium lost an F-16 during an exercise in France, September 23rd. $\endgroup$
    – Mast
    Sep 30, 2019 at 13:01
There are a lot of questions rolled into one here, and I can't answer specifically to the F-16, but a turbine engine needs the same three elements from the basic fire triangle to run: Fuel, Air, Ignition. The element missing from the sequence description linked in the question is ignition.
The igniters are like spark plugs, and they are probably energized during actuation of one of the other mentioned switches. Most likely the JFS switch has a secondary function of energizing the ignitors since it is engine start specific.
Airstarts are not an overly complex procedure, in fact for a single engine aircraft like the F-16 they need to be brief and committed to memory because fighters don't have the best glide ratio.
Fuel - Make sure the throttle wasn't inadvertently shut off, likely the checklist will call for placing this in the idle position. (you need fuel flow, but don't want to dump too much gas into an engine that isn't lit yet!) Perhaps there is a step to turn on a boost pump or switch tanks.
Air - Airborne this comes from outside ram air pressure, as measured by airspeed. The minimum airspeed required envelope will vary with altitude, but most pilots will have a number committed to memory that will provide reliable airstarts across a broad range of altitudes.
Ignition - There will likely be a separate igniter switch for airstarts. Press and hold until lightoff is achieved, then advance the throttles smoothly and resume flying. The airstart ignitor switch is generally located on the power control lever for convenience. If single engine, an alternate electrical power source may be required first in the form or activating a Ram Air Turbine or other source of emergency power to provide a spark if the generator is disabled.
The process isn't really any different from lighting a natural gas stove or propane grill that has a piezoelectric lighter - You turn on the gas and hold the button down or press repeatedly to make the igniter spark until it lights, then release the button and adjust the flame. (in fact when testing the airstart igniters on the ground before flight you listen for a clicking sound to indicate they are sparking!)
So, in its simplest form a generic airstart checklist for a tactical jet would look something like the following example:
  1. AIRSPEED - Maintain 200 KIAS minimum.
  2. THROTTLE - Idle.
  3. AIRSTART BUTTON - Press and hold until light off.
  4. If no relight by 5000 feet AGL - EJECT
    $\begingroup$ Very nice answer. What if the engine doesn't rotate quite as smoothly as it should? Perhaps it ingested foreign material and can turn, but not enough to relight at 200 KIAS? Wouldn't it be a good idea to use the JFS in attempts to force the engine up to a higher RPM? $\endgroup$ Apr 12, 2019 at 12:08
    $\begingroup$ Good question. In the twin jet I flew the procedures said to NOT attempt an airstart if severe mechanical damage was suspected due to the risk of fire. This could be different for a single engine jet. I did fly the single engine TA-4J in training years ago and could reference the manual later for a generic answer, but I'm afraid I can't do anything more than speculate on how an F-16 should respond in such a situation. $\endgroup$ Apr 12, 2019 at 16:02
