I often see people citing the wing flex tests, but with very little reference as to what kind of forces they're designing the plane to take.
I am specifically referring to modern day jetliners such as the Airbus A330.
The wings are tested to withstand 150 of the ''most extreme'' forces the plane will encounter. But what does this mean exactly? Not too long ago, a 777 experienced extreme turbulence, and the aircraft experienced vertical accelerations of +3 G. Would that have still been under limit load for the 777?
  • $\begingroup$ Not a duplicate. This is my first time asking this, thank you. This question is also about turbulence, not a course reversal. $\endgroup$
    – Willy A
    Commented Nov 12, 2018 at 0:57
  • $\begingroup$ At a high level it doesn't matter much whether the load is from maneuvering or from the environment. The regulations cited in the accepted answer to the other question are based on gusts and turbulence. $\endgroup$
    – fooot
    Commented Nov 12, 2018 at 1:28
    $\begingroup$ @WillyA, duplicates are when a question has already been asked by anyone, not a single person. In any case I would agree it's a different question. $\endgroup$
    – GdD
    Commented Nov 12, 2018 at 9:32
The 1.5 relates to the margin between permanent bending (limit or yield load) and breaking (ultimate or breaking load). Transport Airplanes are good to 2.5 limit load at gross weight. Pulling more than that may or may not bend the wings permanently. For ultimate load (pulling the wings off, it's 3.75Gs minimum using the normal 1.5 safety factor)
Those are minimums. There is a lot of safety margin in the stress calculations so I would not be surprised at all to see an airliner take 3Gs without permanent damage even at max gross. If the airplane is below its maximum zero fuel weight (a function of the pax and baggage load, which is where the wing bending is coming from) there is more margin, depending on how light you are.
Then there are the two speed limits to protect the structure to consider. Maneuvering speed is the speed below which a sudden maximum elevator input will reach stalling AOA (thereby unloading the structure) before limit load is reached. Turbulent Air Penetration Speed (TAPS) is the speed below which a theoretical worst case vertical gust will cause stalling AOA to be reached before limit load is reached.
As far as weather conditions, the biggest risk is flying into a thunderstorm cell and hitting extreme vertical gusts (mainly the up going air shaft in the center of the cell), and next to that would be Clear Air Turbulence which is usually related to crossing jet streams and passing through the shearing turbulence sometimes caused at the boundary between the jet stream and the adjacent air mass (jet streams reside in the little corner at the very top of a frontal boundary, in a little triangle of space at the top edge of the warm air mass, next to the adjacent cold air mass and the stratoshere above). Another one is crossing rotors (spinning horizontal shafts of air) that reside below the crests of mountain waves that form downwind of mountain ranges at high altitudes.
For that eventuality you have to slow to TAPS any time you expect to hit severe turbulence like picking your way around thunderstorm cells or flying into areas where Clear Air Turbulence is reported. In the absence of a CAT report, a cautious capt may slow to TAPS anyway if the crew notices that they are passing across a jet stream, just in case (you know you are crossing a jet when your ground speed suddenly changes and the autopilot starts making a sudden heading change to stay on track - it all goes back to normal when you leave the jet).
In theory, staying below TAPS provides protection against permanently bending the wings same as staying below MS protects from bending the wings from a full on elevator input. If the 777 in the incident hit 3 Gs, it suggests that they were above TAPS when it happened but even if it was fully loaded, with the fudge factor in the structural design it's not surprising it wasn't bent from an encounter only half a G above limit load.
  • $\begingroup$ So was the Air India 787 really close to disintegrating in flight, since the turbulence caused accelerations of up to 3 G? Or is there another 50% factor on the 3.7 rating? (Since you said minimum). Thanks $\endgroup$
    – Willy A
    Commented Nov 12, 2018 at 11:05
    $\begingroup$ Probably not because if the structure is designed to 2.5 limit load and 3.75 ultimate load, the worst case is some permanent deformation of the wings not breaking them with a 3G event. I say minimum because while the cert requirement is 2.5G before permanent bending, the structural designers won't make it JUST strong enough for 2.5; there will be some extra to allow for "scatter factor" in the calculations, manufacturing and assembly flaws, ageing, damage tolerance etc. $\endgroup$
    Commented Nov 12, 2018 at 14:05
    $\begingroup$ You see that when at the end of a fatigue program in a wing test rig, where the manufacturer will bend the wing to failure just to see what it takes to snap it, and it lets go way beyond the design limit. $\endgroup$
    Commented Nov 12, 2018 at 14:08
An analysis of commercial aircraft damage due to weather related wind shear may show side loading, rather than G forces, are the cause of excessive stress. Looking at a = f/m, one can see a very large plane will almost behave as a fixed object in wind shear, and leveraging of forces presents the greatest danger.
This was the demise of many of the great airships in the 1920s, when they made a serious bid at transatlantic passenger and mail service and were considered for military applications as well. Those unlucky enough to get caught in severe weather were literally torn in half by wind shear. Their great size worked against them.
These incidents are much rarer in modern times, as faster flying jets are much stronger. But designers should be aware of the weaker points, and pilots should avoid weather conditions that may exceed them.
