How does the electric carbon monoxide detector in cabin or cockpit on aircraft work?
$\begingroup$ You may find the Wikipedia article on Carbon monoxide detector informative. That article mostly talks about home detectors, but the technology is the same. $\endgroup$– Greg HewgillCommented Sep 14, 2017 at 3:27
$\begingroup$ Related, "Carbon Monoxide Detectors" on AVweb. $\endgroup$– minsCommented Sep 14, 2017 at 7:30
3$\begingroup$ The amount of fire-on-aircraft quesitons you are asking is worrisome :-) $\endgroup$– CaterpillaraozCommented Sep 14, 2017 at 10:06
$\begingroup$ I am currently working on description and operation of fire detention systems for my first shop rotation. $\endgroup$– Myat KhantCommented Sep 14, 2017 at 10:08
$\begingroup$ @MyatKhant: Good to know you're not an aspiring arsonist! :-P $\endgroup$– VikkiCommented May 6, 2019 at 3:46
Add a comment
1 Answer
There are three major types of carbon monoxide senors.
- Biomimetic: A gel changes color when it absorbs carbon monoxide.
- Metal oxide semiconductor: When the chip's circuit detects carbon monoxide, electrical resistance decreases, and this triggers an alarm.
- Electrochemical: Electrodes immersed in a chemical solution sense changes in current when they come into contact with carbon monoxide, and this change triggers the alarm.
