Can you explain the different types of fuel quantity sensors used in most recent aircraft?
Are ultrasonic tank sensors used these days? How does an ultrasonic sensor work?
Sign up to join this communityCan you explain the different types of fuel quantity sensors used in most recent aircraft?
From this PPRune forum thread, the Boeing 777 does use ultrasonic sensors (some 20 per tank)
This airplane has some 20 sensors per tank. Each of these is effectively a "radio doppler" and works on the same principle. The sensor calculates the height of fluid by measuring the difference in the speed of the sonic signal sent out thru one sensor to another,as against the ACTUAL local speed of sound (which is a preset value) thru standard temp air.This difference is then converted very accurately into height in the tank in mm.Which translates into quantity of fuel AT THAT sensor given the actual specific gravity of fuel at that point. - King on a Wing
In small aircraft, fuel is measured simply with a floating fuel gauge. In large commercial aircraft, this is accomplished by measuring the capacitance of the fuel.
Ultrasonic fuel sensors seem to be prevalent in stationery ground fuel tanks, not in aircraft.
Ultrasonic fuel sensors use a transmitter/receiver to transmit a sonic pulse inside a pipe filled with fuel. The pulse is reflected back to the transmitter/receiver by the fuel surface and the time taken by the pulse is the measurement of fuel height which is then converted to fuel quantity using the fuel density and specific gravity.
