Reading the ICAO Phraseology Reference Guide I saw the term amendment applied to clearances, and I got a bit confused about how to differentiate it from a revised clearance. What does each one mean? Are there any examples?
1$\begingroup$ In the US, I routinely hear "Callsign 11, I have an amendment to your clearance, advise ready to copy" and also "Callsign 11, revised clearance, advise ready to copy." There is no practical difference that I'm aware of -- in both cases they're giving you a new clearance. There may be some term of art for the controller, but for the pilot it's same-same. Can you link to where you're seeing the two terms used in ways that seem to imply a difference between them? $\endgroup$ – Ralph J Aug 22 '16 at 15:13
$\begingroup$ (pprune.org/airlines-airports-routes/…) revised clearance $\endgroup$ – eduardoguilherme Aug 22 '16 at 16:07
$\begingroup$ (skybrary.aero/bookshelf/books/115.pdf) amendment clearance $\endgroup$ – eduardoguilherme Aug 22 '16 at 16:08
$\begingroup$ ICAO Doc 9432 mentions the phrase RECLEARED, which means: "A change has been made to your last clearance and this new clearance supersedes your previous clearance or part thereof." Which exact document have you found a reference to amendment in? I can't find it in doc 9432 $\endgroup$ – expeditedescent Aug 22 '16 at 18:24
An amended clearance usually indicates something has been added to it, but the original content remains the same. Revised usually means the clearance has had modifications to the original content, including possible additions and deletions.
$\begingroup$ please consider registering an account, instead of creating a new one for each post $\endgroup$ – Federico♦ Sep 1 '16 at 8:16
$\begingroup$ Please add the source for this information to add credibility to your answer. $\endgroup$ – expeditedescent Sep 1 '16 at 15:55
