Is there any technical difference between fuel exhaustion and starvation? And what does it mean if a pilot says he has a "fuel shortage"?
13
Fuel exhaustion means there is no more fuel on board the aircraft. Fuel starvation means there is fuel somewhere, but it isn't available to the engine(s) for any one of a number of reasons: pilot error, blocked fuel lines or valves, malfunctioning fuel pumps etc. You can read a study of exhaustion and starvation incidents here.
A "fuel shortage" isn't a formal aviation phrase as far as I know, but "minimum fuel" is a formal phrase with a specific meaning. This is from the FAA's AIM 5-5-15:
  1. Advise ATC of your minimum fuel status when your fuel supply has reached a state where, upon reaching destination, you cannot accept any undue delay.
  2. Be aware this is not an emergency situation, but merely an advisory that indicates an emergency situation is possible should any undue delay occur.
  3. On initial contact the term “minimum fuel” should be used after stating call sign.
    EXAMPLESalt Lake Approach, United 621, “minimum fuel.”
This question has some more information.
  • $\begingroup$ I would opine that fuel exhaustion would be one cause of fuel starvation $\endgroup$
    – TomMcW
    Dec 1, 2016 at 22:21
I imagine fuel exhaustion means you've run out of fuel. Fuel starvation doesn't necessarily mean you've run out of fuel, just that your engines aren't getting. Perhaps from a clogged filter or line.
