10
I've been trying to find the history of flares (as countermeasures to heat-seeking missiles), but have not had much luck. Closest thing has been this wiki article which has but a single sentence in its history section saying "First deployed during the Vietnam War", with an explicit "citation needed" tag.
Another article is also surprisingly void of history details, and doesn't even have a history section.
Who first conceived of flares as IR countermeasures? When and where were they first used on a large scale?
The only hint I have is that the AIM-4 Falcon was the first IR-seeking AA missile to enter service, doing so in 1956. So presumably flares would not have shown up until that year or later.
The document Genesis of Infrared Decoy Flares- The early years from 1950 into the 1970s by Naval Surface Warfare Center has a lot of details about the work done on decoy flares in the initial stages, at least in the US.
According to the report, the first use of IR flares was not as a decoy, but as a tracking device for drones. The T-131 flare was used in this capacity. From the report:
NOTS, China Lake was involved with infrared target augmentation since 1954. ... The T-131 tracking flare developed at NOTS was the first infrared source for drone use. Six to sixteen of these are needed on the F6F-5K drone to provide a suitable signature.
The first IR flare developed as a countermeasure is the NOTS Model 704, which was developed around 1959. However, the studies on decoys for IR started in the mid fifties, though the concept of using flares came later (the initial concepts were towed decoys). From the report:
The Hayes Corporation, Birmingham, Alabama initiated infrared countermeasures and radiation suppression studies in 1955. ... There was a need about 1957 to create a decoy device that would simulate the signature of a turbojet engine. Instead of the pyrotechnic decoy flare approach, ... proposed an inflatable envelope that absorbs the energy from a self-contained pyrotechnic and re-radiates this energy at a lower temperature approximating that of the heated surfaces of the turbojet engine.
Initial flares (RR-77, probably) were fitted in the B-47 and B-52 bombers, which were deployed through the AN/ALE-14 dispenser around 1960. Though the report has indications that the flares were used in the Vietnam war, there is no data on the exact time and location of the use of flares in combat. However, we can be sure that the IR flares were used in combat in Vietnam. The report says,
In 1967, Dr. Edwards of Air Development Test Center at Eglin Air Force Base, requested Picatinny Arsenal to improve the ALA-17 flare. The Air Force wanted a quick fix to the poor rise time of the ALA-17 flare. They also required that a single ALA-17 flare would have decoy capability to protect B-52 bombers in Southeast Asia against seekers operating in the 2μm to 3μm and 3μm to 5μm bandpass.
indicating feedback from combat operations. Though I'm sure that the Soviets too were developing IR flares at the same time, not much detail is available about their effort.
My father commanded a Stinger AC 119 squadron in SE Asia in the early 1970s. I don't recall the exact dates except that he was there before May 1972 and retired from there in about March 1973. He would tether airmen outside the planes so they could spot incoming heat seeking missiles and fire off flares to draw the missiles away. Eventually, the Air Force replaced this primitive but effective deterrent with equipment that did not require men to fly while hanging outside the plane. You can imagine how scary that would be!
My father is Lt. Col. Albert W Brow, retired.
