10
Are there any FAA regulations concerning wireless Bluetooth headsets in the cockpit of any aircraft? Moreover, I'm interested in finding out if the Bluetooth protocol (IEEE 802.15.1) will adversely affect any aircraft avionics in terms of radio interference or other Electromagnetic Interference (EMI). If anyone has any experience with this, thoughts and comments would be greatly appreciated.
  • $\begingroup$ I'm on the fence as to whether this question is too broad. $\endgroup$
    – Steve V.
    Mar 25, 2014 at 1:36
  • $\begingroup$ It probably should be two questions, though both are good ones $\endgroup$
    – SSumner
    Mar 25, 2014 at 1:44
  • $\begingroup$ I do not think the question is too broad. Both I and my friend have not been able to find an answer to the question. I have seen commercial bluetooth aviation headsets for pilots that want to stream music while also talking to ATC (although I don't know how safe that really is). But I was hoping that there were some aviation professionals that had experience in this area that they could share. $\endgroup$ Mar 25, 2014 at 2:07
  • $\begingroup$ You can also find some more info in this question: aviation.stackexchange.com/q/2141/69 $\endgroup$
    – Lnafziger
    Mar 25, 2014 at 12:34
  • $\begingroup$ Yeah I saw that question but I'm not really worried about not hearing auditory cues like ATC or engine noise so much as I am EMI. Thanks though. $\endgroup$ Mar 25, 2014 at 19:28
There are multiple aviation headsets approved by the FAA that have built-in Bluetooth.
Based on that, I'm going to say that this has been tested and will not interfere with the aircraft avionics. Radio/EMI testing is part of the testing that any device approved by the FAA for use in an airplane must go through.
    $\begingroup$ You can also find "TSO'd headsets" with Bluetooth (the Bose A20 is one example) -- of course the applicable TSO (TSO-C139) only cares about the headphones & microphone :-) $\endgroup$
    – voretaq7
    Mar 25, 2014 at 4:53
    $\begingroup$ That makes sense. Thanks for the info. $\endgroup$ Mar 25, 2014 at 12:14
