I can't think if I've ever seen this be done with the L
on the left and theR
on the right. Even on my Rotax 914, which is, *ahem*, modern and doesn't have magnetos, the key is still labeled with R
on the left and L
on the right.
Why?
on the left and L
on the right.
Why?
This website gives a good explanation which I'll repeat here.
But… deep breath… selecting the right-hand key position grounds out the right mag, essentially turning it off, while leaving the left mag running — so the right key position is marked with an “L.” Likewise, moving the key to the left (but not all the way to OFF) now disables the left side, leaving the right side working — hence the “R” label at the left key position.
Key position dictates what’s “off,” while the label shows what’s on. So there is a certain logic to it, once you embrace it.
For a more detailed explanation see the website itself
