Is it possible or feasible for an aircraft to continuously cruise at the speed of sound? Is the drag at this point higher or lower than in the high Mach 0.98 or Mach 1-1.2 region?
1 Answer
As shown in the following plot (from this answer), the F16 has a drag coefficient which doubles at transonic speeds but then remains basically constant past Mach 1.
So an F16 could definitely do it. And for a more modern aircraft, the rise in drag would even be more contained.
$\begingroup$ I'd like to see that plot for an F-22 or other fighter that can cruise supersonically without reheat for comparison. Not sure if the F22 needs reheat to get there, then can cruise at military power, or if it can go moderately supersonic with military power alone. $\endgroup$– John KCommented Feb 12, 2023 at 20:42
1$\begingroup$ @JohnK: I'd also like to see that... and obviously the one of the Concorde 🙂 For a supercruiser (like the Concorde) I'd expect only a peak in the drag coefficient at transonic speeds. Afterwards the coefficient should be just a bit higher than at subsonic speed. $\endgroup$– sophitCommented Feb 12, 2023 at 21:43
$\begingroup$ @JohnK the Super Tomcat would also have been able to supercruise. $\endgroup$ Commented Feb 12, 2023 at 23:29
