Russian/Soviet aircraft design has always intrigued me, and even more so when coming across this photo of the Tupolev Tu-134UBL with its pointy nosecone.
Having looked up the performance characteristics of the aircraft, it "only" seems to fly at sub to trans-sonic speeds (max. speed 890km/h or Mach 0.72 at sea level).
Based on my limited knowledge reinforced by this great post, it only makes sense to use a pointy nose cone when the aircraft travels at supersonic speeds.
Therefore, would the reason for the nosecone design be for some other function rather than just aerodynamics? Radar? Tupolev Tu-134UBL
According to Wikipedia, the UBL variant of the TU-134 was designed/used to train TU-160 crew, and is using its nose-cone.
As to why, I think we can only assume. I think that a fair assumption would be that it contains the radar from the TU-160 (or a stripped-down version of it), and/or so the crew will have a similar visibility as they would on a TU-160.
The overall performance differences between the TU-134 and 160 are too far apart (the -134 being a subsonic airliner and the -160 being a supersonic bomber) for the shape of the nose cone alone to make any sort of a significant difference.
