Another answer stated that Airbus was less focused on just brand image, and more on aerodynamics, explaining the more rounded nose of it's 320 vs the 737's. But it still has flat cockpit panes which very conspicously NOT flush with the nose.
The same cannot be said of the A220, which is not much smaller, or even of the A350 which Airbus themselves developed.
    $\begingroup$ You should link the question, not just refer to "another answer". $\endgroup$
    – Therac
    Commented Jun 8, 2020 at 18:04
    $\begingroup$ farm7.static.flickr.com/6034/6312829920_819784b2e2.jpg if anyone wants a picture reference $\endgroup$ Commented Jun 8, 2020 at 23:02
    $\begingroup$ Don't forget A320 is 40 years old while the other two are brand new! $\endgroup$
    Commented Jun 9, 2020 at 7:03
Cockpit windows that sit flush with the fuselage can save a very small amount of drag, but they require large double curvature window panes. Manufacturing such panes is significantly more expensive and there was limited commercial availability for that product when the A320 was being designed.
You can see a few more examples of flat vs curved windows here: https://www.airliners.net/forum/viewtopic.php?t=754093
Cost and availability are a serious concern, as the A320 was already expensive compared to the competition. Paying more and risking delays if double-curved glass production couldn't be ramped up would not have been worth the savings. Airliners aren't just about performance, the very name "Airbus" hints that they're also a public conveyance.
In short, only the newest airframes get to make that small drag saving. Some older airframes had single curvature windows, which are between flat and double-curvature in complexity.
This has been explored in more detail in a broader question.
