As you can see in this picture the bottom of the fuselage curves upwards to form the nose.
  • $\begingroup$ sorry if you guys do not understand my question please tell me what you think it means and I will tell you if that's what I mean. $\endgroup$
    – Ethan
    Commented Aug 25, 2015 at 23:22
  • $\begingroup$ If it didn't curve, how would you imagine it to be? Like a race car with unidirectional curve? $\endgroup$
    – Alexus
    Commented Aug 25, 2015 at 23:46
  • $\begingroup$ @Alexus It makes me think of my airplane design has a nose that doesn't curve up, but other than that I can't think of anything else. Can't show you a pic because I don't have it drawn yet. $\endgroup$
    – Ethan
    Commented Aug 25, 2015 at 23:48
  • $\begingroup$ @Alexus I mostly ask this question because of my airplane design nose to make sure its aerodynamic $\endgroup$
    – Ethan
    Commented Aug 25, 2015 at 23:49
    $\begingroup$ @Ethan, a curve like that car's would not be aerodynamically neutral; it would create a slight downward force on the nose of the airplane. $\endgroup$
    – BillDOe
    Commented Aug 26, 2015 at 5:39
4 Answers 4
Having the tip of the nose in the centre gives best combination of aerodynamic performance, weight and internal volume. If you move the tip down, the slope above it will either be steeper, leading to higher drag, or longer, leading to greater length and thus weight; or you don't extend the plane, but then the longer sloped part will provide less internal volume. Only the cockpit windows, which need to be on the sloping part, shift the nose a bit down, to the centre of the cross-section just before cockpit.
Cars are different. For a car you want the bottom surface flat, because you don't want to push and compress air in the gap between the vehicle and the ground. But aircraft has air all around and it is most efficient for it to push air equally to all sides, so a circularly symmetrical shape works best.
Also note that lift is yet another thing. Lift requires a sharp, downward-sloped trailing edge.
    $\begingroup$ A straight nose will have no pitch moment, while bending the centerline of the fuselage down in front will add a downforce there which will need to be balanced by more downforce at the tail. $\endgroup$ Commented Aug 26, 2015 at 14:52
The nose of the aircraft has to satisfy a number of requirements, some of them contradictory, like
  • The nose shape should produce the least drag
  • The pilots should have good visibility
  • It should house the weather radar and related avionics
  • The cockpit noise should be minimal
For example, the aerodynamic design of Concorde meant that the nose had to droop during takeoff/landing for good pilot visibility.
For aircrafts flying in transonic regime, some of the best nose shape from aerodynamic standpoint would be to have a symmetric body of evolution based on Haack series of curves.
Haack Curves "Nose Cone Haack Series" by Andersenman - Created with Gnuplot using the Haack series formula and a selection of input values for C relevant to the article. Values are 0, 0.333, 0.667, 1 and 1.333.. Licensed under CC0 via Commons.
However, due to fact that the cockpit is on the upper part of the nose region, this arrangement increases the complexity of cockpit windows (they will have to be curved in two axes, atleast) if the pilot has to have good visibility. As a result, center of the the nose is usually moved downwards.
This is the reason for the common profile seen in aircraft noses.
However, the disadvantage of this profile is that the pressure is high in the windshield region compared to the flat profile.
Curved Vs Flat Cabin Source:AGARD LS-67, Paper-4
The main problem with (dual) curved cockpit windshield is the tighter quality control required and the associated costs. However, in 787, Boeing has achieved a continuous surface variation.
787 Nose
Source: airliners.net
It is to be noted that the aerodynamics is only one of the criteria for nose design. For example, a nose with similar profile to that of 787 was proposed for A350. However, it was later changed to accommodate other considerations.
A350 nose profile change
According to Didier Evrard, executive vice-president A350 programme,
There have been a number of trade-offs in the nose area, enabling us to maximise the volume of the cockpit and avionics bay while optimising aerodynamics and the positioning of the nose landing gear
A350 nose
"A350xwb nose 2009B" by Luis E. Contreras. Licensed under CC BY-SA 3.0 via Commons.
The RAF's Hawker Siddeley Nimrod does.
Source: Wikimedia
But only because it is an anti-submarine aircraft; its radar is designed to point at the sea, not the air. Of course you could still put weather radar in a downward-pointing nose, but that would be a waste of space and engineering. Commercial aircraft strive for efficiency, and in this case it makes more sense in terms of balanced aerodynamics and instrument placement for a jetliner to have a nose that curves both upwards and downwards.
Also take a look at another view:
Where would you put the baggage?
    $\begingroup$ Well, Nimrod is a weird example because it had a second fuselage basically strapped to the bottom of a Comet. However, Comet has a similar if less extreme version. $\endgroup$
    – egid
    Commented Aug 27, 2015 at 0:16
    $\begingroup$ There are more common aircrafts. Have a look at Embraer, Avro RJ, and all that business jets. Most of them have the nose down. $\endgroup$
    – sweber
    Commented Aug 28, 2015 at 21:11
Just to add to other answers, evenly sloped fuselage on the top and bottom in the front of the aircraft would create lift and drag somewhat equally in top and bottom direction, thus rendering fuselage aerodynamically neutral like BillOer mentioned in comments.
If you were to design fuselage like the vehicle below, downforce generated by the upper part of the fuselage would push the whole assembly downwards - this is desirable for road vehicles as the more planted on the road they are, the better. For aircrafts however, balance is the key: enter image description here
  • $\begingroup$ Looks like a lifting body to me. And this thing would nail kids in the driveway every time it came home. $\endgroup$
    – user2298
    Commented Feb 3, 2019 at 4:51
