- I already read Why do fighter jets still have guns/cannons?, but it doesn't expound why 100-200 rounds suffice or how "6 seconds is actually a lot of 'gun time' for modern air-to-air systems considering speeds, targeting systems and lethality of the projectiles involved."
I acknowledge that "It's not like WWII anymore where you'd slowly pull up behind a bomber and then have to spend several seconds pumping a bunch of crappy .50-cal lead in, hoping to poke enough holes in an oil cooler to make a difference."
Revolver cannons
Rotary cannons
"The F-35A is armed with a 25 mm GAU-22/A rotary cannon mounted internally near the left wing root with 182 rounds carried". The Dassault Rafale fighter "is equipped with the GIAT 30-millimeter cannon with 125 rounds of ammunition."
MiG-35 "is also armed with the 30 mm Gryazev-Shipunov GSh-30-1 autocannon with 150 rounds.". "The Su-35's armament includes a GSh-30-1 30mm autocannon with 150 rounds".
