How does the MiG-29 fuel system work? Like, where does it store around 300 cubic feet of fuel?
Also, which fuel does it use? Is JP4 preferable?
Sign up to join this communityHow does the MiG-29 fuel system work? Like, where does it store around 300 cubic feet of fuel?
The aircraft is equipped with seven (7) integral fuel tanks: five (5) Center body fuel tanks and two (2) wing tanks. Center body fuel tank #2 serves an an engine feeder tank with all other tanks transferring fuel to it via a network of fuel pumps for consistent weight and balance. The aircraft can be refueled by means of a single pressure refueling receptacle located in the port main landing gear well.
(Source: Luftwaffe MiG-29 Flight manual)
Like every plane, the MiG-29 stores its fuel in fuel tanks ;)
On a more serious manner:
Generally speaking, there are 6 internal fuel tanks: 4 distributed around the fuselage and 1 in each wing.
Later versions (namely the SMT) have larger internal fuel capacity thanks to the enlarged spine.
The exact locations of these tanks can be seen in this cutaway (src): 63, 72, 93, 107, 187.
In addition to these, the 29 can also carry 3 (1 in the very early versions) jettisonable external fuel tanks.
