31
A relative of mine showed me the following picture that she took on the 11th of April, around 8 to 8:30 pm in the Netherlands somewhere near "Leiden" pretty close to Schiphol airport (unfortunately I do not know the direction she was looking at, or the exact location, nor does she remember).
This relative thinks that what is shown in this picture is a rocket ascending due to the steep vertical incline. I however doubt this and rather believe it is a plane flying towards the photographer. The illusion of it ascending steeply being caused by the shadow of the earth falling close to the "plane" while the distant contrail is still in sunlight due to the height at which a plane flies, creating a fake depth effect.
What makes me doubt my theory however is the (to me seemingly) irregularly shaped contrail at the end which look like the plane did some weird zigzagging (or a very strange wind blowing it like that), and it seemingly "just appearing" out of nowhere
Now we both don't know a lot about airplanes, so I was wondering if by looking at these contrails it is possible to confirm or deny that this is caused by an airplane.
Looking at the flightradar for that moment there appears to only have been one plane in the area, and even that appears to be quite far out. Could this plane possibly have left those contrails?
  • 21
    $\begingroup$ The direction of the photo should be west – the setting sun is just right of the right edge. While the jagged contrail really resembles that of rockets, the light on its more remote part clearly shows that is is from an aircraft. A rocket contrail in that condition would become brighter the higher you go, and this becomes darker as the aircraft moves eastwards. $\endgroup$ Commented Apr 13, 2020 at 5:50
    $\begingroup$ Obligarory XKCD: xkcd.com/1677 $\endgroup$ Commented Apr 14, 2020 at 6:18
    $\begingroup$ @I'mwithMonica: I raise you: xkcd.com/1669 $\endgroup$
    – user14897
    Commented Apr 14, 2020 at 14:45
    $\begingroup$ The zig-zagging is caused by winds. $\endgroup$
    – Hot Licks
    Commented Apr 14, 2020 at 17:03
    $\begingroup$ @HotLicks: nope - that's the rocket flying an evasive course to dodge the flying saucers which patrol Earth-space to prevent us from resupplying our advance base on Mars. Oh, wait - I wasn't supposed to reveal@#)(&@)#%^*(@#$@#()&)$(#*@!NO CARRIER $\endgroup$ Commented Apr 14, 2020 at 22:39
61
I am pretty sure it is an aircraft.
When aircraft fly straight towards you they can appear like rockets. The contrail is distorted by winds in the upper airspace. Yesterday there were a lot of cirrus fibratus and cirrus uncinus in the upper atmosphere (at least above Frankfurt, and we are in the same weather system at the moment), and when aircraft fly through them the contrails typically wobble like in your picture.
Now, which aircraft was it?
The aircraft visible on the picture is not flying in sunlight anymore, but most of its contrail still is. It also just made a turn.
On the eleventh of April, sunset in Leiden was at 20:33 local time (18:33 UTC), setting in a bearing of 285 degrees.
Flightradar24 show this DHL Airbus A330 descending from FL 390. I would estimate that this picture was taken at 20:36 local time, perhaps a bit later. The turn is clearly visible on the picture and on FR24. The contrail matches that of a large twin engine. (my first guess was a 777, an A330 has a similar contrail. It is definitely not a 747).
A comparison picture created by ymb1 shows the shadow/lighted parts of the contrail highlighted, contrasted with the terminator on the map.
    $\begingroup$ Amazing information about those winds, clearing up our biggest question! (Awarding you the checkmark for that) $\endgroup$
    – Remy
    Commented Apr 12, 2020 at 20:23
    $\begingroup$ "Yesterday there were a lot of cirrus fibratus and cirrus uncinus in the upper atmosphere (at least above Frankfurt, and we are in the same weather system at the moment), and when aircraft fly through them the contrails typically wobble like in your picture."-- I would suggest that these types of clouds are indicative of high moisture in upper atmosphere, allowing contrails to linger for a long time, allowing wind shears to distort them-- as opposed to being directly indicative of wind shear. I may be wrong, perhaps in some way they do directly indicate wind shear as well. $\endgroup$ Commented Apr 12, 2020 at 21:52
    $\begingroup$ Thank you for that bit of education. $\endgroup$ Commented Apr 12, 2020 at 21:57
  • 25
    $\begingroup$ Going from "is this a contrail from an aircarft?" to identifying the exact flight and time - I love this site! $\endgroup$
    – Aleks G
    Commented Apr 13, 2020 at 8:54
    $\begingroup$ @DeltaLima Amazing analysis. Can you provide some insight into what it is about this contrail that indicates a large twin, as opposed to a four engined aircraft (ex 747, A380)? My completely uneducated eye doesn't know what to look for. $\endgroup$
    – dgnuff
    Commented Apr 14, 2020 at 4:26
16
+50
That is a contrail from an airplane, not a rocket.
The wideness of the trail at the bottom part of the photo makes it clear that it has been lingering for some amount of time. The distortion is clearly due to the effect of wind shear acting on the lingering trail, not due to radical maneuvers.
Rocket engines burn for a relatively short time, and rockets have steeply climbing trajectories. If that dot at the end were an actual rocket, the portion of the trail at the bottom of the photo would be only a few minutes old at most, which is unlikely to be enough time for changes in wind velocity with altitude to produce that much distortion in the lingering contrail. Also, it is difficult to think of a scenario where a rocket's steeply climbing exhaust trail would be sunlit on the bottom and shaded on the top. The opposite would normally be true-- as in this incredible photo from the Space Shuttle mission STS-98.
STS-98
Image from NASA
It is not that uncommon for an airplane's basically horizontal contrail to look like this. The distant portion, which is at the bottom of the photo, may be well over five minutes old, allowing wind shears more time to distort the trail-- although in truth this much distortion would be more common in a case where the trail had been lingering for several tens of minutes, with the airplane itself long gone. But in fact I have taken a photo much like this, with the airplane still approaching, and joked with somebody standing beside me about the "crazy maneuvers" that it looked like the aircraft had undergone. Of course when the aircraft passed overhead it was clearly just a commercial airliner flying in a straight line.
The sun is clearly located toward the lower right of the picture--see the diagonal shadow streaking up and left from one of the sharp "bights" in the trail. Note that a similar diagonal shadow line is faintly visible running up and left from the very bottom right corner of the photo. Follow both lines down and right and see that they converge at a point below and right of the lower right edge of the photo-- the sun is clearly below the horizon as seen by the camera. The sun is also clearly below the horizon as seen from the aircraft's current position-- as suggested by another answer, the aircraft has clearly flown past the terminator of the sunrise or sunset, passing into the shadow of the earth itself. This would be very unlikely with the near-vertical trajectory of a rocket. In the rare event that it did happen, the photo would look quite different than this-- you would see the trail rising up steeply and then arcing over toward a more horizontal trajectory in a way that just doesn't fit what we see in this photo.
While other answers have pinned down with confidence the exact time and location of the flight, note that the principles applied in this answer could be applied to any similar photo without knowing any more information.
Let's close out this answer with a few more notes on the spectacular photo from the launch of STS-98. This mission was launched just after sunset. Although the trajectory is arcing over the toward the east, the extreme altitude gained in the vertical part of the trajectory has caused the vehicle to pass from shadow into sunlight, rather than vice versa. Note the long shadow, cast through the still-sunlit upper atmosphere by part of the exhaust plume itself, ending at the anti-solar point just below the moon, which is about half a day from being exactly full. The shadow is made more visible by the fact that that much of the dust-and-moisture-filled lower atmosphere between the observer and the shadow is already shaded by the earth itself, reducing glare.
Someone standing 5 miles away would have seen something quite different-- the shadow line might not have been visible at all, or a different part of the trail might have been aligned to cast a visible shadow line. Of course, the shadow (if visible) would still slant through the sky at the same angle, and would still end at the distant anti-solar point, just below the almost-full moon.
For a contrail or exhaust plume to cast a visible shadow through the atmosphere like this, a significant segment of the shadow must be directly aligned with the observer or camera. This can only happen when a significant segment of the contrail itself is directly aligned with the sun as seen by the observer or camera. In other words an imaginary line extended from that linear segment of the contrail must appear to pass directly through the sun as seen by the observer or camera. The easiest way to catch a glimpse of this phenomena in action is watch for an instance where a long, linear contrail is just upwind of the sun as seen from your position. As the contrail drifts through the sun and then downwind of the sun, its aerial shadow will appear and then vanish again. Then another observer standing further downwind will have a chance to observe the same thing. The aerial shadow from a contrail or exhaust plume is like a pane of window glass-- it is invisible unless you are looking at a significant length of it directly edge-on.
  • 9
    $\begingroup$ A rocket going up would indeed have its "head" lit by the sun while its "tail" would be in the shadow, as greatly illustrated in this photo by NASA $\endgroup$
    – Ruslan
    Commented Apr 13, 2020 at 9:41
  • $\begingroup$ @Ruslan -- amazing-- added links and description to answer $\endgroup$ Commented Apr 13, 2020 at 15:26
That is just an illusion. The aircraft is flying straight and level and the contrail behind it is being distorted by the winds aloft.
