Wikipedia mentions,
ZZZZ is a pseudo-code, used in flight plans for aerodromes with no ICAO code assigned.
How pilot actually file this flight plan? Is there anything special to do when file for ZZZZ.
Sign up to join this communityWikipedia mentions,
I don't know if you're asking about a specific country, but in the US it seems that you can just use it in place of a regular airport identifier and add supporting information in the remarks.
Specifically, the AIM 5-1 has several references to it, including:
(b) If no four-letter location indicator has been assigned to the departure aerodrome, insert ZZZZ and specify the non-ICAO location identifier, or fix/radial/distance from a nearby navaid, followed by the name of the aerodrome, in Item 18, following characters DEP/,
(c) Then, without a space, insert the estimated off-block time.
EXAMPLE-
- KSMF2215
- ZZZZ0330
The same wording is used for both FAA and ICAO flight plan instructions.
