Question 1: If I am flying in uncontrolled airspace and I have an emergency, should I report on 121.5MHz if no ATC is within line of sight communication (which means I cannot hear the ATC and the ATC cannot hear me)?
Question 2: Which frequency should I use to report the emergency in the following scenario? When the emergency happens, the aircraft is in uncontrolled airspace but near or approaching controlled airspace. There is an ATC station which is in charge of that airspace and the aircraft is within the line of sight of ATC (which means I may hear them), but my onboard radio coverage (the green circle indicated in the picture) cannot reach the ATC station (which means ATC cannot hear me). Should I report on the ATC frequency as maybe some aircraft are flying in the area and can relay the emergency to notify the ATC? Or should I just keep reporting on the common radio frequency like 121.5MHz?
