16
In 2009, a Grob 103 glider stalled and crashed at Richmond Field, Michigan, killing the passenger but not the pilot. (NTSB accident report: CEN09LA353)
The accident occurred after a failed winch launch; during the winch launch, the tow cable broke while the glider was about 400 feet AGL. The pilot correctly decided to turn around and return to the airport.
Here's what happened next, according to a statement the pilot later gave:
I could feel in the controls that something was not right and the glider was not responding in the manner that I am accustomed. There were none of the signs of a stall and the glider did not behave like it has any time that I have practiced stalls. Before I could determine the cause or take any action, the nose abruptly dropped and we dove toward the intended runway.
The NTSB report about the accident states that the probable cause of the accident was simply the pilot's failure to maintain adequate airspeed, resulting in a stall. Judging by this, the NTSB didn't seem to put much stock in the pilot's report that "something was not right".
Suppose that we take the pilot at their word, however. Is there any type of abnormal condition that might have caused a "feeling in the controls that something is not right", and which could cause the nose to drop with "none of the signs of a stall" occurring beforehand?
    $\begingroup$ Please, If possible try to find out if PIC manged to detach the broken cable $\endgroup$
    – jean
    Oct 10, 2018 at 20:54
  • $\begingroup$ @jean I could ask the pilot if they pulled the release, but do you think that's a good idea? $\endgroup$ Oct 10, 2018 at 21:07
  • $\begingroup$ As much as I'd like to find out if the pilot managed to release the broken cable, I'm not aware of a reasonable way to try to find that out. If you think I should try to find that out, please suggest a way I can do so. $\endgroup$ Oct 11, 2018 at 15:10
  • $\begingroup$ Not saying that that's actually what happened here, but a flight-control failure could generate all the symptoms described. $\endgroup$
    – Vikki
    Oct 14, 2019 at 3:54
17
Your question:
A couple of thoughts:
  1. In a 60 degree level bank turn, stall speed increases by about 40%.
  2. See below for information regarding indications of an approaching stall in the G103. (from the G 103 C Twin III Acro manual)
g 103 info-1 g 103 info-2
The flight manual, section 4, indicates that with aft cg there is a stall warning 2-3 kts before reaching stall speed - (read) "There is a tail vibration which increases with continuing pull on the control stick." I think the note above (highlighted in yellow) means that with forward CoG, at max weight, there is no stall warning at all, i.e., the glider just stalls (nose drops without warning). I could be wrong, but this seems to me to be what the note means.
Here is a copy of the manual for the Grob G103 Twin III Acro: Grob G103 flight Manual
Here is a copy of the NTSB report I believe covers this accident: Grob 103 Accident - NTSB Identification: CEN09LA353
    $\begingroup$ I don't quite understand the yellow highlighted note. Is it saying that at max weight and forward CoG position, the limit on elevator control deflection will act to limit the angle of attack, making it impossible to even get close enough to a stall for tail buffeting to occur? $\endgroup$ Oct 10, 2018 at 21:03
    $\begingroup$ @TannerSwett- The flight manual, section 4, indicates that with aft cg there is a stall warning 2-3 kts before reaching stall speed - (read) "There is a tail vibration which increases with continuing pull on the control stick." I think the note means that with forward CoG, at max weight, there is no stall warning at all, i.e., the glider just stalls (nose drops without warning). I could be wrong, but this seems to me to be what the note means. $\endgroup$
    – user22445
    Oct 10, 2018 at 22:36
    $\begingroup$ Seems to indicate that at forward CG and max weight and at low speed, not enough aerodynamic force to reach stalling AOA from pulling the stick, but, once it starts to sink from lack of airspeed, the change in relative wind will stall it and, additionally, will flip the nose down from up force on the tail. Not good close to ground. $\endgroup$ Oct 11, 2018 at 2:05
    $\begingroup$ Is it possible that the passenger, who wanted to learn to fly glider, somehow touched the control and disrupted the pilot's maneuver? $\endgroup$
    – gadfly
    Oct 11, 2018 at 3:20
    $\begingroup$ This. If the NTSB couldn't come up with a better explanation than pilot error, then that's probably a very reasonable conclusion. It sounds like the pilot was not experienced flying with passengers in this aircraft and did not expect the change in stall behaviour under those loading conditions. $\endgroup$
    – J...
    Oct 11, 2018 at 12:00
13
Possibly a Center of Gravity beyond the aft limit could do it, but with 2 adults on board I don't think that's likely unless the person up front was really small and the PIC failed to load ballast to bring the front seat weight up to the minimum. The NTSB report doesn't say anything about loading so that seems to be a non-issue and there were no other anomalies with the airplane that they could find. Possibly really bad bug contamination on the leading edges could also affect the stall behaviour and maybe that could've been a factor the investigator overlooked. Pretty unusual to see gliders with bugs allowed to accumulate that badly, however.
One of the problems with winch launches is when a cable breaks at 400 ft like that, you are in the worst possible place to be, directly over the middle of the runway. There is no way to get aligned with a runway to land without a fair bit of maneuvering and turning, and you're high enough that landing more directly toward an off-airport field is out of the question, since 400 feet is a lot of altitude to play with in a 35:1 glider, so psychologically the tendency is to be hell bent on landing on the grass directly below you one way or another. With that kind of unpleasant surprise with the stress level dialed up, it's likely the pilot simply did not perceive the pre-stall behaviour while concentrating on getting lined up.
In gliders the pre-stall cues can be fairly subtle by power plane standards, obvious enough during deliberate practice but easy to miss when mentally loaded up with a life and death do-it-now task. So if I was going to bet a large sum of money on a likely cause, I'd go with the pilot stalling and spinning an otherwise normal glider from failure to maintain flying speed while maneuvering, regardless of what his recollection is.
