How do turbochargers improve engine performance at high altitudes / density altitudes?
Could you also address how this benefit could become a liability at low density altitudes, for example when the density altitude is negative?
1$\begingroup$ See my related question, and the good answers there. $\endgroup$– abelenkyCommented Dec 30, 2013 at 21:15
2$\begingroup$ John Deakin has a really good series of articles on AvWeb describing aircraft turbochargers: avweb.com/news/pelican/182102-1.html $\endgroup$– guidoismCommented Dec 31, 2013 at 16:24
An oversimplification for sure: Turbochargers essentially compress the air going into the engine (cylinders) to maintain (near) sea level pressure internally, so the external density altitude doesn't affect the performance of the engine.
The "liability" at low density altutudes is that it is possible to over-boost the engine, potentially damaging it. See the related question for more in-depth explanation and the liability of having a turbocharger at low density altitude.
1$\begingroup$ Also worth noting that - as mentioned in the answers on the other question - normally aspirated engines will produce greater than rated power at negative density altitudes. This factor is generally ignored because it's not as substantial a difference as you see with turbochargers, but it's why I can cruise in the yellow arc at 65% power in my lowly PA28 Cherokee in winter. $\endgroup$– voretaq7Commented Dec 30, 2013 at 22:40
$\begingroup$ @voretaq7: but would that not have the same internal pressures as 75% or more at standard conditions? $\endgroup$ Commented Jan 1, 2014 at 10:25
1$\begingroup$ @Qantas94Heavy Yup, and around the same equivalent power production - more air to push around everywhere (in the cylinders & around the prop). $\endgroup$– voretaq7Commented Jan 1, 2014 at 17:44
Turbochargers increase available engine performance by increasing the amount of fuel/air mixture that can be burned in the cylinders. This is accomplished by compressing the air before fuel is mixed in.
The performance of a reciprocating aircraft engine is directly dependent on how much fuel can be burned and converted into heat energy, which in turn is converted into kinetic energy (motion). The amount of fuel that can be burned is dependent on how much air (actually the oxygen in the air) is available to burn with the fuel. An increase in altitude causes a decrease in air density and therefore less air available to be burned with the fuel. In a non-turbocharged (technically a "normally aspirated") aircraft engine, the reduction in available air will cause a corresponding reduction in available power. A turbocharged engine overcomes this deficiency by compressing the air brought into the engine, thereby increasing the amount of fuel that can be burned with the air, and increasing the amount of power available.
The turbocharger will rotate at a higher RPM at altitude, compressing the air such that the amount of fuel & air entering the combustion chamber is nearly the same as at sea level. From idle to full power will take longer at altitude and it may not be possible to successfully restart such an engine at high altitude until you have descended to an altitude where pressure is more favorable to start the engine.
