Let's say we have a Cessna 150 with a Continental O-240.
How is the density altitude performance hit split between the engine air intake and the propeller ability to "grab" the air.
Let's say I was able to put a engine on it that would not be affected by density altitude.
What would the remaining penalty be on the aircraft performance due to the propeller still being affected?
  • $\begingroup$ I don't claim to be an aerodynamics expert but this may be kind of broad. I think it would depend greatly on the length of a propeller and the volume of the engine cylinders. Generally, longer, wider propellers and larger engine cylinder volumes would be negatively affected more rapidly with decreases in density altitude. $\endgroup$ Jul 1, 2016 at 22:13
There is no reciprocating gas engine or gas turbine which is not affected by density altitude, the density of the air directly affects how much mass of working fluid can be taken in by the engine for a given volume of air and as a consequence the amount of power it can develop for a given fuel consumption. The less dense the air, the less power or thrust the engine can develop.
Turbocharging or supercharging a reciprocating engine can maintain uniform power outputs for a throttle input provided the density altitude does not exceed the critical altitude of the turbocharger. Turboprop and turboshaft engine are generally 'flat-rated' ie the fuel controller maintains a uniform power output right up to the thermodynamic rating of the gas generator at altitude.
As for propellors, the thrust they can deliver is directly proportional to the density of the ambient air, so higher density altitudes mean less thrust for a given power input from the engine.
Performance tables for both engines and propellors are available from the manufacturer and vary between make and models. In general, pilots really don't use this as much as the aircraft performance tables in the POH for a particular aircraft.
