12
I live a few miles from a major airport (BOS), under the path that a lot of airplanes use to depart. The planes are somewhat low over my house -- high enough that it's not deafening, but low enough that I can make out the livery. Judging from a couple planes I just looked at on flightaware.com, I'd guess somewhere in the 5,000 - 8,000 foot range.
I can often make out three fairly distinct sounds from the planes:
  • a mid-range roar, the sort that one would typically associate with a jet flying overhead
  • a sort of whistling
  • sometimes a buzz
The buzz isn't always there, but when it is, it's quite loud; significantly more noticeable than the other two.
What causes each of these sounds? I know there are different components of an engine (I'm guessing the main ones for this question would be the fan, compressors, combustion chamber, and turbines, and possibly the nozzle). I'm guessing each contributes to some, but not all, of the sounds.
If it matters, my house is around where the planes turn (they often take off heading more or less NW, and then turn west or SW where I can see them). I think the buzzing (when I can hear it) is loudest when the plane is at about a 45 degree angle to me (so I'm seeing its front-left as it's climbing), but I wouldn't swear to it.
  • $\begingroup$ An airframe alone contributes a surprising amount to an aircraft's noise. When an aircraft is gliding much of what's heard is not from the engine. $\endgroup$
    – STWilson
    Jun 13, 2017 at 3:02
    $\begingroup$ @STWilson Hm, interesting. That could be I've of the sounds. The Wikipedia article on the Gimli glider suggests it's not much noise, though: "Complicating matters was the fact that with all of its engines out, the plane made virtually no noise during its approach. People on the ground thus had no warning of the impromptu landing and little time to flee." $\endgroup$
    – yshavit
    Jun 13, 2017 at 3:26
  • $\begingroup$ As I think about it, the noise from the engines radiates in all directions as it's being generated internally and "pushed" out. The wind noise from the fuselage cutting through the still-ish air (Gimli Glider) is mostly being left in the wake of the plane as it's passively generated, thus the GG's noise wasn't a warning for those in front of the plane. IANAAE I am not an audio engineer... $\endgroup$
    – FreeMan
    Jun 13, 2017 at 11:45
  • $\begingroup$ Related: this (very similar), this $\endgroup$
    – Pondlife
    Jun 13, 2017 at 12:27
12
There are several dimensions to the answer on this topic. First, consider that different flight profiles (TO, approach power, final approach power, etc) will have different engine acoustic signatures. The sound output from a jet or turbofan is not linear with power, rather it changes with power level, and resulting flows and RPMs. Second, consider that the polar acoustic radiation is different for the aircraft. Nose down vs nose up, banked, etc. and consider that these radiation patterns are changing with respect to power. These are the primary noise factors.
Secondary noise factors include APU operation, and airframe noise. The airframe noise is greatest with airspeed which impacts boundary turbulence energy, and then with gear extension, and flap/slat/spoiler extension and slips.
To this complexity add airspeed, and aircraft configuration.
Different engines have decidedly different spectral content, and some are quite characteristic.
The bulk of the engine noise is exhaust turbulence, and quite specifically the differential of the exhaust velocity and the ambient flow. This is why turbofan engines are much more quiet, because they have a more gradual gradient between the ambient flow, and the jet flow.
Whines are often forward directed radiation and are largely acoustics from the intake, and most specifically from fans on turbofan engines.
There is a plethora of literature on A320 engine whine and solutions with different engines.
There are also some specific airframe noises. For example, the same aircraft, the A320 has some open vents on the lower wings, and the addition of vortex generators has been shown to reduce this noise substantially (up to 11db, which would be perceived as half the noise, and is a more than 99% acoustic energy reduction. Some A320 aircraft can be heard from 30 miles away.
To address your questions, the roar is mostly engine noise. The whine is also engine noise, but can sometimes, on some aircraft be port or acoustic flutter noise. The buzz noise is normally airframe or to a much lesser degree airframe and engine interactions.
Apart from civil aviation there has been a lot of work done, and thousands of papers written on acoustic signatures of aircraft. There are various sensors equipped with correlation software which will classify aircraft in the air, from the ground. Aerospace contractors work hard to reduce the signatures of every aircraft from large transport to fighters. Civil aviation responds to different threats, which are the public complaining about noise associated with airports near cities.
  • $\begingroup$ As I commented above, the buzz seems too loud to be from the airframe alone. Do you have any citation for that? I may have mis-described the sound; I looked up a video, and it's the buzz that's at 2:03 here. Seems to be coming from the engine. $\endgroup$
    – yshavit
    Jun 13, 2017 at 17:37
    $\begingroup$ Inlet fan shockwaves is my guess. Flying with my buddy who flies A320 later this week and can ask him. $\endgroup$
    – mongo
    Jun 13, 2017 at 17:49
  • $\begingroup$ Ah, that makes sense! $\endgroup$
    – yshavit
    Jun 13, 2017 at 17:56
  • $\begingroup$ Talked with him briefly on phone, and he suggested you might look at a320whine.com. Not the noise mentioned above, rather the FOPP, but you might find it interesting. $\endgroup$
    – mongo
    Jun 13, 2017 at 18:41
  • $\begingroup$ Huh, that whine does sound similar to the whistling noise I meant! And it'd make sense, since I don't think that's on every plane either, now that I think of it. That page only mentions it happening on arrival, but there's no reason it wouldn't also happen shortly after takeoff, right? $\endgroup$
    – yshavit
    Jun 13, 2017 at 18:49
