In this blog I read about the Quiet Flight Initiative, which - if I understand correctly - will be quieter than a comparable carbon fueled plane at least in part because it is electric. It's an engineering challenge associated with Embry-Riddle Aeronautical University.
What aspects of the plane design - when switching from combustion engine to electric motor - will help reduce noise? I had thought that most external aircraft noise heard on the ground (in this case, National Parks) is associated with the propellor, and so noise is closely linked to performance, not the particular method of torque generation.
