I figured out there are currently 2 different FAA websites for NOTAM online search:
What is the difference of each one? Which one is better to use? Do both of them provide information about Distant (D) NOTAMs, Local (L) NOTAMs and FDC NOTAMs?
  • $\begingroup$ The FAA will transition to FNS October 01, 2016. $\endgroup$
    – user16354
    Aug 10, 2016 at 12:37
I got this response via email from the FAA:
PilotWeb is considered a Legacy Application based on the USNS, United States NOTAM System. The FNS, Federal NOTAM System, NOTAM Search is a new application. Many Legacy applications will eventually be replaced with the newer FNS applications over the next year. Both applications should be able to provide you with the information you are looking for.
    $\begingroup$ Can you give a link to that quote? $\endgroup$
    – Pondlife
    Jul 21, 2016 at 23:35
  • $\begingroup$ It was a FAA response that I got via email. $\endgroup$ Jul 29, 2016 at 19:49
  • $\begingroup$ Thanks, I was wondering because the last page updates at the FNS link are from 2014 (the NOTAMs themselves are current, though) so it was hard to say if the site is actually in use or not. I suspect the key word from the email is "eventually" :-) $\endgroup$
    – Pondlife
    Jul 29, 2016 at 19:56
