I am not sure if this is the correct place to ask this because it has to do with APIs with XML/JSON/SOAP, but it also has to do with aviation.
I am in dire need to find an API associated with the FAA to get NOTAMs for areas and airports. NOTAMs are Notices to Airmen, and it will be a useful feature in a service I am creating.
I have done extensive searching for a NOTAMs API, but I cannot find anything except this: https://notams.aim.faa.gov/notamWFS/
However, this website requires registration which is just a broken link. Any suggestions on how to use this?
Do you know of any other NOTAM APIs available? Also, if possible, do you know of a weather API which has the same information included in an ATIS/AWOS reporting station?
I was able to find working APIs for US regulations and general weather (not specific enough) and pilot information, but I cannot find any for specific weather or NOTAMs.
EDIT: A friend of mine was able to click the registration button, and it didn't give him an error. He sent me the link and I am now trying to register on the site I found.
    $\begingroup$ If this path does not work, you could still build your own API by scraping the adequate pages. Might end up being somewhat more flexible than dealing with XML/SOAP requests. $\endgroup$ May 29, 2018 at 8:16
  • $\begingroup$ That approach has a downside @Stanislasdrg, website changes can leave developers scrambling. $\endgroup$
    – GdD
    May 29, 2018 at 11:19
  • $\begingroup$ @Forseth11, the ICAO has global notams database which may be of interest: icao.int/safety/iStars/Pages/notams.aspx. $\endgroup$
    – GdD
    May 29, 2018 at 11:20
  • $\begingroup$ @GdD it works! Thanks so much! $\endgroup$
    – Forseth11
    May 29, 2018 at 17:26
    $\begingroup$ Echoing Aviaton Weather for METAR information. Provides JSON formatted data based on given inputs (GPS, station code). $\endgroup$
    – ksea
    Sep 3, 2018 at 0:03
As @GdD mentioned in the comments, there is an API for NOTAMs here: https://www.icao.int/safety/iStars/Pages/notams.aspx
You also asked for metars, which you can get from here: http://tgftp.nws.noaa.gov/data/observations/metar/cycles/${TIME}Z.TXT where ${TIME} is the hour of the Zulu time you are interest in, wrapped between 0 and 23 (eg. 16)
