On this article about Sporting Event TFRs on the Flight Service website, they mention unpublished TFRs:
Play Ball! Be Aware of Sporting Event TFRs June 26, 2016 when you ask the specialist for TFRs along your route of flight or request an online briefing, you may expect the specialist to provide unpublished TFR information that is not associated with the “blanket” sporting event TFR. Ensure you check your route of flight for the possibility of a Sporting Event TFR or published TFR.
What is the difference between a published and unpublished TFR?
From the article I would infer that Sporting Event TFRs are considered published, but I don't think they are published anywhere else but in the NOTAM. Appearing in a NOTAM is not considered as being published, right?
Where are the published TFRs being published now? NOTAMs used to be published in Notice to Airman Publication (NTAP). But, from these notes on the FAA website it seems that NTAP is being retired. So, where would the NOTAMS be published moving forward?
  • $\begingroup$ Can you quote the wording from the article? The link you posted just takes me to the homepage. $\endgroup$
    – Pondlife
    Nov 15, 2020 at 22:54
  • $\begingroup$ Play Ball! Be Aware of Sporting Event TFRs June 26, 2016 when you ask the specialist for TFRs along your route of flight or request an online briefing, you may expect the specialist to provide unpublished TFR information that is not associated with the “blanket” sporting event TFR. Ensure you check your route of flight for the possibility of a Sporting Event TFR or published TFR. $\endgroup$
    – rvernica
    Nov 16, 2020 at 0:45
It looks like you have two questions: what's an unpublished TFR, and where are NOTAMS published?
First, unpublished TFRs. I can't find any FAA information on "unpublished TFRs" and I suspect it was just poor phrasing from FSS. I read the article you linked and it's unclear what they really meant, at least to me. Having said that, you could interpret "unpublished TFR information" in two ways:
  1. Unpublished information about TFRs
  2. Information about unpublished TFRs
I believe the intention was #1. There's a blanket 'stadium TFR' NOTAM but it doesn't include key information, like when the TFR is active for a given stadium. That's because games schedules change and the FAA doesn't keep track of them; it's up to the pilot to know if there's a game going on or not. For that reason, the stadium TFRs are very unpopular with pilots.
But, FSS might still tell you if a stadium TFR is active. Especially for major, high-profile events like the Super Bowl. There's no guarantee that they can or will, though, especially since FSS has become more centralized and less local.
Second, NOTAMs. The FAA currently publishes them here: https://notams.aim.faa.gov/#News
I say "currently" because the FAA seems to like moving things around and breaking links. But as you can see from that site, you can search yourself and there's also an interface that other systems can use.
Finally, that brings me to the practical answer to both your questions: just use your favorite flight planning app. I use Garmin Pilot, which displays current and future TFRs, and it keeps track of sporting event schedules. It also has NOTAMs, of course. Foreflight or other alternatives would do that too, I'm sure.
The stadium TFRs are usually easy enough to work around because - except for really big events like the Super Bowl - you can fly through them anyway if you're talking to ATC. So if you can get flight following (always a good idea) then you're complying with the TFR requirements.
  • $\begingroup$ I was on flight following and unaware of a stadium TFR. ATC informed me and asked me to go around the entire surface-area class C next to the stadium. $\endgroup$
    – rvernica
    Nov 16, 2020 at 3:58
  • $\begingroup$ You can also find TFRs at tfr.faa.gov without having to sort through the NOTAMs. $\endgroup$
    – Gerry
    Nov 16, 2020 at 12:33
