17
I've lived near several airports and have grown accustomed to a certain noise a jet plane makes when passing overhead: a swooping sound, very bass-heavy, that dives rapidly in pitch, maybe 1.5 seconds in duration. It happens toward the very beginning of the plane's audibility and is followed by the normal sound of the jet passing above.
Is it simply the Doppler effect as the plane passes overhead and its noise rapidly changes?
Or is there a mechanism on the airframe whose actuation on an approach might make this sound? Sometimes the same plane makes this sound more than once, which makes me think it isn't simply the Doppler effect.
  • $\begingroup$ The Doppler effect - partly covered by some of the answers here: aviation.stackexchange.com/questions/14557/… $\endgroup$
    – Andy
    May 10, 2016 at 8:43
  • $\begingroup$ Could be a chang in engine speed as well. If power is increased or reduced you will hear a relatively loud "spooling" noise. $\endgroup$
    – acpilot
    May 10, 2016 at 16:05
    $\begingroup$ Interestingly gliders make an almost identical sound when they fly overhead, they sound just like jets, so it's not just the engine noise. Good to listen when they're 100ft above you. $\endgroup$
    – D. Clayton
    May 10, 2016 at 18:01
14
The effect you noticed is the result of the combination of Doppler effect and sound absorption.
Sound absorption in a fluid is proportional to
$exp(- \alpha \nu^2 x)$
where $\alpha$ is a dimensional constant, $x$ is the traveled path, and $\nu$ is the sound frequency.
In its own reference frame, the airplane emits always the same sound, irrespective of whether it is approaching or receding from the observer. But for the observer, the frequency of a wave (which is $\nu_0$ in the plane frame) seems $\nu_a = \frac{\nu_0}{(1-v_j/c_s)}$ when the airplane is approaching, and $\nu_r = \frac{\nu_0}{(1+v_j/c_s)}$ when the plane is receding (here $c_s$ is the sound speed and $v_j$ the airplane's speed). Thus the perceived frequency jumps by a factor
$F = \left(\frac{1+v_j/c_s}{1-v_j/c_s} \right)$
This means that the absorption coefficient, at the time when the airplane is passing overhead (thus $x \approx H$, the plane's height over the ground), jumps from
$D_a = \exp \left(\frac{-\alpha H \nu_0^2 }{(1-v_j/c_s)^2}\right)$
to
$D_r = \exp\left(\frac{-\alpha H \nu_0^2 }{(1+v_j/c_s)^2}\right)$
For typical values for the atmosphere, and the propagation of sound waves in it, this means that $D_a \ll 1$, while $D_r \approx 1$.
Hence, what is happening is that, as the airplane passes roughly overhead, the sound goes from being deeply absorbed, especially at high frequencies, to not being absorbed at all (its normal sound, as you call it). The strange sound you noticed is what you perceive as the lower frequencies are becoming less and less absorbed, and thus the sound spectrum changes.
EDIT 1:
after I wrote my reply, DClayton (in a comment above) gave a very important hint that this is exactly what is happening when he noticed that the same effect appears with gliders, hence it is unrelated to engine sounds (I ignored this, thanks).
EDIT 2:
it is also worthwhile remarking what happens for high-altitude planes, when observed from the ground: in that case, the traveled distance $x$ is sufficiently large that all frequencies audible to human ears are absorbed, so that the plane goes from being nearly silent when it is approaching to being very clearly noticeable as it is receding.
You may try this on a clear day with high humidity at high altitudes, when over-flying jets leave white wakes: you will be unable to hear them as they approach (even though you can see them thanks to the presence of the white wake), but you can easily hear them as they go away, but just keep in mind that all of this is delayed by the (substantial) time it takes for sound to reach the ground, which, for 33,0000 feet or more, is of order 30 seconds. In other words, you will hear the noise level grow perceptibly about 30 seconds after the jet has passed the point closest to the observer, i.e. 30 seconds after flying directly overhead.
    $\begingroup$ this is fascinating. I have always wondered about this sound change, and now I know! $\endgroup$
    – Peter
    May 10, 2016 at 16:30
There are at least three effects that can cause this
Doppler-effect
When a source of noise moves to you, you'll hear the noise with higher pitch, and when the source moves away, you'll hear it with lower pitch. This can be described by this formula, which gives the ratio of frequencies head by you and sent by the source of the noise moving with speed $v$, at speed of sound $c$:
$$\frac{f_{heard}}{f_{send}}=\frac{1}{1-\frac{v}{c}} $$
Since aircraft pass by in some distance, you can't just enter the speed of the aircraft, but this:
$$v=\frac{v_{aircraft}\cdot x}{\sqrt{x^2+y^2}} $$ where x is the horizontal and y the vertical distance to the aircraft.
I plotted this for two different speeds and several altitudes, and put the time until passing you on the x-axis:
This shows that the total shift in frequency is larger for higher speeds and that the time the sweep takes is shorter, the nearer the aircraft passes by. BUT an airliner will not fly at 1000ft with 270kt, its more 135kt.
In general, the aircraft has to fly at really low altitude to cause a noticeable doppler effect. Here is a youtube video of a landing A320, recorded near the runway.
I didn't take into account other effects like that speed of sound changes with altitude. Also Marius Matutiae meanwhile wrote something about absorption of sound in air.
Engines
Something you can observe in that youtube video, too, is that you can clearly hear a high, screaming noise from the fans in the beginning, which changes to a dumb rumbling from the jet blast after it passed by.
Flaps
Most aircraft make some noise when deploying flaps, and I would say, the Avro RJ100 is one of the loudest airliners concerning this. The reverse effect can be heard when retracting the flaps, also from inside the aircraft (2:40)
    $\begingroup$ The flaps sounds is it. I knew I'd have trouble describing the noise but it is not just the Doppler effect on the engines. Thanks for this! $\endgroup$ May 10, 2016 at 16:12
