This is not a direct answer for the 777. I don't know if Boeing is going to disclose the exact mechanism used today, for security reasons. Still they filed a patent shedding some light on how it could work.
From the patent:
- Each panel is locked by an articulated hook (428 and 432)
- The hook is locked by a pin (438) in a hole.
- The pin is controlled by the pressure sensor (436).
When the pressure difference between door sides exceeds a threshold, the pin is recessed, releasing the hook, the panel can swing in both directions freely. The full process is fast enough to be compatible with an explosive decompression.
More:
In the second article it is said the panel can be closed/reset after the sensor has been triggered.
From what I read, there are single-plate panels and panels made of multiple small slats, protected by a grid to prevent any intrusion when the panel is open.
